bleeding air from cooling system - 1963 220s - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 06-17-2016, 08:29 PM Thread Starter
Scoot's Avatar
Date registered: Oct 2002
Quoted: 102 Post(s)
New radiator, new thermostat, new water pump. I filled everything with water and everything worked correctly - the thermostat opened at the right time and kept the engine at the right temperature.
So today I drained the water from the petcock on the radiator bottom and on the side of the block and filled it back up with 60/40 Zerex G-05/water. Started the car and it went to normal operating temperature, I turned around for a couple of minutes and the needle was on the other side of the gauge.
Turned car off (duh) and felt upper and lower radiator hoses. Upper is really hot and lower is really cold. So the thermostat isn't opening. Why? I'm guessing that there is an air pocket in the lower thermostat housing. There is no bleed screw.
Ideas? Help?
Scoot is offline
post #2 of 2 (permalink) Old 06-22-2016, 04:24 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: slc5.0cab 280sl5sp 280se4.5 500sl92 GONE:280sl79 4xW114/5 3x450sl72-3 280slc4sp81 280s69 73,81SLCs
Quoted: 1574 Post(s)
I know on the v8 107 model cars the guys say to "burp" the system by lowering the rear as low as you can and raising the front as high as you can, and then letting the car run up to operating temperature for a bit. Also, continue to top off the system with coolant.
Honestly, I'm not sure how this works other than hopefully getting the air out of the engine block. I would think an air pocket in the water pump would be the worst possible thing.
My signature:
My dream car is a classic sporty five speed (stick+overdrive) convertible that seats five. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
