W111 Horn ring , beeping issues. 1962 220b - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-07-2016, 07:29 AM Thread Starter
Date registered: Jan 2008
Vehicle: 1999 E320
Quoted: 7 Post(s)
I had a sloppy column shifter so I replaced the two bushings and my improved shift pattern and ease of getting into reverse was the benifit. HOWEVER , now my horn sounds unless I leave the steering wheel loose on the shaft.
there are many pieces
brass horn ring
steering column ring - holds the brass ring in
the "wavy wire"
the spring
the two part early version of the steering wheel
I think I am getting it back together correctly but cant seem to keep the horn from honking...they are daggone loud horns too...
any thoughts -is something missing in my parts list. Where exactly does the wavy wire go ??
Ron
1999 E320
62 220b
84 300SD
72 450SL
71 220 Parts
81 380 Sl - Parts
Bondjames is offline
post #2 of 3 (permalink) Old 06-07-2016, 02:18 PM
nostat's Avatar
Date registered: Nov 2015
Vehicle: 1974 450SEL
Beeping horn
I had to change the steering coupler which required the steering shaft to come out. After putting everything back together I started the car and the horn was blowing constantly. Found out I had pinched one of the wires and when I started taking the steering wheel off the horn stopped. Hope this helps.
nostat is offline
post #3 of 3 (permalink) Old 06-08-2016, 10:51 AM Thread Starter
Vehicle: 1999 E320
Quoted: 7 Post(s)
thanks , it came down to clearance, a small teflon washer at the base of the steering spindle in the housing seems to have done the trick
Ron
1999 E320
62 220b
84 300SD
72 450SL
71 220 Parts
81 380 Sl - Parts
