109 sel engine bay - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 05-16-2016, 02:19 AM Thread Starter
Date registered: Apr 2016
Vehicle: 1972 300 SEL
109 sel engine bay
Hi,
My new purchase got a great cut and polish last week, and now is looking the goods. Next is now a clean on the inside.
But first what is the best way to clean engine bay and get rid of oil leaks?
ID:	1881002   Click image for larger version
300 SEL is offline
post #2 of 8 (permalink) Old 05-16-2016, 06:24 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 460 Post(s)
Simple Green works great for cleaning.
Clean everything, the locate your leaks by keeping an eye on things.
rumb is online now
post #3 of 8 (permalink) Old 05-16-2016, 10:55 AM
Bergermiester's Avatar
Vehicle: 57 300sl Roadster, 71 280se coupe 3.5, 71 280se cabriolet 3.5
Quoted: 6 Post(s)
I would agree with Rumb, however gunk is always a good choice as well if the grease is thick. Also you can use heavy duty non-flammable degreaser, I use that with a parts cleaner brush and get great results.
Good luck and keep us updated!
-Bergermiester
Bergermiester is offline
post #4 of 8 (permalink) Old 05-16-2016, 05:54 PM Thread Starter
Thanks, high pressure cleaning ok?
Im concerned about electrical and injectors
300 SEL is offline
post #5 of 8 (permalink) Old 05-16-2016, 07:31 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1679 Post(s)
It always helps if you fill out your profile so we understand what model car you have. You could have sensitive d-Jetronic electrical wiring harness on a 3.5 or 4.5, or the early mechanical injection on an m130 or 6.3.
So please fill out your profile to help us help you.
Location is always helpful too.
My signature:
Click for list of my 32 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #6 of 8 (permalink) Old 05-16-2016, 09:53 PM Thread Starter
Thanks Fonzi,
Purchased in Australia.
Its a 1972, 3.5 with D jetronic wiring system.
300 SEL is offline
post #7 of 8 (permalink) Old 05-18-2016, 08:30 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Wiring will be brittle and cracked if the harness hadn't been replaced in the past. Thus, pressure washing might be a bad idea. However, if you keep the flow down low and away from the intake and injectors, you'll be ok.
I second the notion of Simple Green. Spray it liberally throughout the engine bay and let it sit a while. A garden hose and nozzle will take most of the gunk away.
Grubeguy is offline
post #8 of 8 (permalink) Old 05-27-2016, 04:42 PM Thread Starter
Would you believe i used oven cleaner and it work the best. Sprayed on warm engine then light spray with the hose and boom.
rabskyline likes this.
300 SEL is offline
