water leak from.... left side of engine block?!?! - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 05-07-2016, 10:38 AM Thread Starter
Cheetahpop's Avatar
Date registered: Mar 2013
Vehicle: 1971 220D
My 1971 220D has been sidelined for 20 months after a head gasket failure and an electrical gremlin that I finally have cornered. It is back together and I put 1/2 gallon water in the radiator. Then I heard water running.... I found a small stream coming from just under/beside the fuel injector pump on the left side of the engine block. First thought: oh, no! there was water and not enough anti-freeze left and something froze. Second thought: Maybe this is where all the coolant went in the first place, although the head gasket was bad. (There was orange residue from antifreeze on the #4 piston head plus a white plume of smoke trailing me at the time.)
Before I pull off the newly timed injector pump, someone please tell me there's a hose or a plug under there is easily fixable. I don't think duct tape is going to fix this one.....
Cheetahpop is offline
post #2 of 3 (permalink) Old 05-11-2016, 11:29 AM
Date registered: Jan 2007
Quoted: 85 Post(s)
I don't have an engine to look at, but I was in the EPC and took a look. Behind the injection pump, there is a large screw plug and a sealing ring. They seal the water jacket. That's my guess as to the problem.
Sorry.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #3 of 3 (permalink) Old 05-11-2016, 05:19 PM Thread Starter
Cheetahpop's Avatar
Vehicle: 1971 220D
Thanks, Chuck! When I saw that stream, I knew it had to be something like that. And either way, I guess I'd be taking the injector pump off... but I know what to expect.
Glancing at your info, it reminds me that I have some cousins in Chantilly I need to visit...
