Can the M130 engines run lead free? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-26-2016, 06:41 AM Thread Starter
Jackpody's Avatar
Date registered: Oct 2012
Vehicle: Mercedes Benz W108 - 280 SE (1970) / Mercedes-Benz W123 200T (1983)
Quoted: 13 Post(s)
Hi Benzworld!
Very simple and easy question - can the M130 engines run on lead free petrol? I do believe the M130 engines are aluminum heads, which should mean the valve seats are already hardened (but do correct me if I'm wrong with the above information!).
I've always added Shell's lead additive to my fuel, but do I actually need it? The previous owner did it as well, but he said it "could probably run without, I just add it for peace of mind".
Thanks!
Jackpody is offline
post #2 of 3 (permalink) Old 04-26-2016, 07:39 AM
Date registered: Aug 2009
Quoted: 70 Post(s)
No need for added lead. Benz (and most if not all European petrol engines) have had the hardened seats since the early '60's.
Mike D is online now
post #3 of 3 (permalink) Old 04-29-2016, 02:11 AM
suktinis's Avatar
Date registered: May 2009
Vehicle: Ferguson TED-20 1956, Mercedes-Benz 220 S 1963, Valmet 502 1973, Mercedes-Benz S 500c 1996
Quoted: 5 Post(s)
I belive the official guidelines also say that you should check valve clearance twice as often; at least initially. otherwise it should be completely compatible
suktinis is offline
