How and where to attach the engine to the crane/hoist?? Help! - Mercedes-Benz Forum
post #1 of 8 (permalink) Old 04-25-2016, 08:12 AM Thread Starter
Kaelor's Avatar
Date registered: Apr 2015
Vehicle: 1970 W115 200/8
Quoted: 24 Post(s)
Hello, I wonder if anyone knows how to lift the engine out and into the car with a crane. I got myself one of those 2 ton cranes but I don't have any idea where to hook it up with the chains.
It's an M115 engine from the w115 200, modern engines have some lifting points but this one doesn't seem to have any. I have a chain and two hooks but I need to find a safe place where to lift it from. Please some help would be appreciated.
Kaelor is offline
post #2 of 8 (permalink) Old 04-26-2016, 05:09 AM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 48 Post(s)
You need to attach a cable under the Vee pulley at the front and a cable at the oil pan at the rear. Elevate the front about 30 degrees and lift up and out.
Will
Baybear is offline
post #3 of 8 (permalink) Old 04-26-2016, 06:44 AM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 37 Post(s)
I like to use a six foot sling. Positioned behind the lower oil pan, it gives a pretty good angle. The angle can be adjusted some by sliding the sling forward or back within the limitations of the mount arms and other accessories. A floor jack under the transmission pan is also useful for clearing the crossmember.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #4 of 8 (permalink) Old 04-26-2016, 07:24 AM Thread Starter
Kaelor's Avatar
Quoted: 24 Post(s)
Thanks for the reply, those are good ideas but how about using chains?? I already have a nice chain to lift it with
Kaelor is offline
post #5 of 8 (permalink) Old 04-26-2016, 07:54 AM
Date registered: Aug 2009
Quoted: 72 Post(s)
Depending on the size of the chain you can slip a length of heater hose over it as a cushion and treat it as a sling. There's really no good place to secure a chain on the left side of the engine unless you pull the engine mount arm.
I usually put the chain/sling behind the mount arms.
You know you'll need to remove the bonnet due to the angle the engine must be tilted to clear the front body crosspiece.
Mike D is offline
post #6 of 8 (permalink) Old 04-26-2016, 08:01 AM
1mbzdoc's Avatar
Date registered: May 2014
Vehicle: 2010 glk350 91 560sec 74 230 66 220seb 86 300e 88 300e
Quoted: 194 Post(s)
Remove valve cover and pull one head bolt from front and one from rear attach one end of chain to front by putting head bolt through chain link and back into engine then same for rear.
Or you can go down to wrecking yard and get the brackets off the front of any old mb diesel and use those with the head bolts and chain
Kaelor likes this.
current stable
2010 glk350-86 300e-88 300e white-88 300e blue-66 220seb-74 230-89 560sec white-91 560sec taupe?-92 300te-83 380se parts car- 2012 chevy cruze eco wifes commutor 40plus mpg on regular. 1970 gmc 2500- 2002 gmc 2500hd duramax/allison-50s something willeys pickup- 74 scout-88 jetta karat-74 harley fxe-92 harley flhtcu ultra classic-95 harley road king-96 harley fatboy-98 special construction harley powered.- 2011 klx250 and to many off road vehicles and coming soon 69 280sl
1mbzdoc is offline
post #7 of 8 (permalink) Old 04-26-2016, 08:16 AM Thread Starter
Kaelor's Avatar
Quoted: 24 Post(s)
I was thinking about using the head bolts too but was afraid they couldnt cope with the weight. So it is safe to use them then?
Kaelor is offline
post #8 of 8 (permalink) Old 04-26-2016, 08:23 AM
1mbzdoc's Avatar
Quoted: 194 Post(s)
I have been using them for more than 20 years and have had no problem just screw them in till the link is tight to the head no slack in bolt or they could bend
Kaelor likes this.
current stable
1mbzdoc is offline
