rubbers - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 04-14-2016, 05:07 AM Thread Starter
seventysix300d's Avatar
Date registered: Apr 2012
Quoted: 2 Post(s)
Gents, Im looking to change out all of my rubber bushings. I will of course be doing this on the ground. What is the best place for me to put the jack for the following.
Ball joint
Sway bar
Im concerned of the built up energy when the bolts are removed if I place the jack in the wrong place. Thank you
Holla, holla, holla, holla, holla, let me holla at you. holla holla holla. -Anthony Berry
seventysix300d is offline
post #2 of 3 (permalink) Old 04-14-2016, 05:14 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: slc5.0cab 280sl5sp 280se4.5 500sl92 GONE:280sl79 4xW114/5 3x450sl72-3 280slc4sp81 280s69 73,81SLCs
Quoted: 1570 Post(s)
Personally I have found the sway bar links to be easiest to remove and replace while the weight is evenly distributed on each side, like when the car is sitting on the ground.
I haven't ever done the ball joints myself.
My signature:
My dream car is a classic sporty five speed (stick+overdrive) convertible that seats five. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 3 (permalink) Old 04-14-2016, 06:54 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 1968 250S, 1991 300se, 1998 SL500, 2x 1977 450SEL 6.9. Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 405 Post(s)
sway bars are easier to remove if you only jack one side up. that puts preasure on one side that lowers the other. You need to jack from the frame to do this.
For other suspension work, again I would jack from the frame, as that will lower the wheel and spring preasure on the side you are working on.
For the ball joint you are taking the entire side apart, use a spring compressor as indicated. Use search to find others that have already done this.
Bergermiester likes this.
rumb is online now
