Rich running 4.5 any advice? - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 03-27-2016, 11:53 AM Thread Starter
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 58 Post(s)
Hi All
I just fitted the petronix ignition module (1885). The car starts right up and runs lovely. But ever since I fitted it, the car is running to rich. The gas mileage is not good at all. Can anyone tell me the steps to check to dial it in properly? The car always ran very nicely before, with good spark plug color and reasonable gas mileage for a 4.5.
Happy Easter.
Cheers John.
wroding is offline
post #2 of 7 (permalink) Old 03-28-2016, 10:16 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 99 Post(s)
Hmmm, looks like my previous reply didn't stick...
The thing that hits my mind immediately is the air temp sensor connection. Without it, the car runs more rich. Is it possible you broke a wire or connection while removing the air cleaner (assuming you removed it?)?
At idle, the mixture adjustment is on the ECU itself. Under load, the mixture is adjusted at the MAP sensor. When I installed my pertronix, the mileage actually improved ...
Grubeguy is offline
post #3 of 7 (permalink) Old 03-28-2016, 01:18 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
Checking the temperature sensor wiring is a good start (bad coolant sensor can cause rich mixture).
Higher than standard fuel pressure will cause rich mixture.
Perhaps timing is off? Hook up a timing light, and first check that you get fast advance from about TDC to 25-30 BTDC as you rev from idle to ~3000rpm. It's possible that the Pertronix may be preventing the centrifugal advance from working by binding on something.
If advance is working properly, set timing so it is at about 27 BTDC at 3000rpm - at idle it will be at TDC or even 5BTDC.
In order to adjust mixture using ECU (for idle) or MPS (for load), you really need an exhaust analyzer or AFR gauge. Before doing this, I would check:
- both temperature sensors
- fuel pressure
- timing
- all vacuum lines are connected.
BTW, did you install 1885 just as points replacement or did you also bypass the switchgear?
1972 350SL 4.5L - MBGraham, near Kingston, Ontario
MBGraham is offline
post #4 of 7 (permalink) Old 03-28-2016, 04:47 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1679 Post(s)
I like mbgraham's timing suggestion. That's one thing that's pretty much guaranteed to change when moving from points to pertronix.
My signature:
Click for list of my 32 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #5 of 7 (permalink) Old 03-28-2016, 10:46 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Pertronix igniter unit does change the timing and requires advancing the ignition quite a bit ,first noticed that on my M130 engine .
adler is offline
post #6 of 7 (permalink) Old 03-31-2016, 08:49 PM
Date registered: Mar 2013
Vehicle: 1972 280SE 4.5
I have the same issue after a Pertronics install. MBGraham recommends checking both temp sensors. Is this done by measuring resistance? If so, what should they read?
Ron F
Ronfeuer is offline
post #7 of 7 (permalink) Old 04-02-2016, 10:22 PM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
Hi Guys.
I did go back in to check and adjust the timing. I set as you suggested MBgraham. It seems to have done the trick Before my plugs were very dry, sooty and black. I cleaned them, did the adjustment, then drove around for about 25 miles. Now they have a very nice sandy color. The car seems to run very smooth. I am checking gas mileage at the moment but so far it seems heaps better
Thanks everyone for the suggestions and help.
All the best John.
ps. I did the 1885 straight points replacement.
Thx
wroding is offline
