M130 timing chain gear - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 03-18-2016, 04:12 AM Thread Starter
Date registered: Oct 2015
Quoted: 9 Post(s)
I am stripping the engine down and there is a gear in the timing chain chase. The shaft the gear is on also drives a worm gear to the distributor. I tried to pull the gear and now have 2mm play (play from front of motor to back, up and down in the picture)
how is this gear and shaft removed? there is an access panel on the front of the motor, but it does not give you access to much, just a better look.
donlawson84 is offline
post #2 of 2 (permalink) Old 03-18-2016, 11:08 AM
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
turn and pull up.
kavadarci is offline
