M117 distributor o-ring groove - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 03-13-2016, 01:39 PM Thread Starter
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 39 Post(s)
Does anyone have a M117 distributor that can measure the slot for the o-ring. I'm trying to build a plug for mine (converting to individual coils). Trying to find out the outside diameter and diameter at the o-ring slot.
TZ_280SEL is offline
post #2 of 11 (permalink) Old 03-14-2016, 05:22 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1835 Post(s)
It sounds like you need a distributor out of a car. I think I might have a spare in my w108. It's really raining here right now though. So I will wait for your confirmation before running out in the rain and pulling the cover off the car.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 11 (permalink) Old 03-14-2016, 07:28 AM Thread Starter
TZ_280SEL's Avatar
Quoted: 39 Post(s)
Fonzi, correct....but don't get wet. I'm likely not working on it again until this weekend...plenty to keep me busy.
I'm converting to Megasquirt and LS1 coils, so I'm going to machine a plug using same o-ring to seal off the distributor hole. Just trying to get it all built prior to taking her off the road. If need be, I can pull my distributor , measure, and reinstall but if someone has one out of a car, it would save me having to set timing etc..
I appreciate it.
post #4 of 11 (permalink) Old 03-14-2016, 07:51 AM
Fonzi's Avatar
I notice your profile says "euro 4.5 engine". Is this a d-jet? What number engine is it you are using?
(I hadn't seen that before.)
My signature:
Fonzi is offline
post #5 of 11 (permalink) Old 03-14-2016, 08:22 AM Thread Starter
TZ_280SEL's Avatar
Quoted: 39 Post(s)
Yes, it is a D-Jet. Engine is from a 1974 450SLC euro....117-982
The distributors are the same size, but I think the advance is different on the euro. Part of my desire to go to megasquirt for ignition is being able to give the car a bit more aggressive timing curve to take advantage of the higher compression of the euro engine.
post #6 of 11 (permalink) Old 03-14-2016, 09:12 AM
Fonzi's Avatar
This is from a d-jet 117.983 w116 motor that was installed in a 73 US Spec 450slc I parted out.
M117 distributor o-ring groove-imageuploadedbyautoguide1457971933.108882.jpg
Let me know what dimensions you need.
My signature:
Fonzi is offline
post #7 of 11 (permalink) Old 03-14-2016, 10:11 AM Thread Starter
TZ_280SEL's Avatar
Quoted: 39 Post(s)
I need the diameter just above or just below the o-ring. Ideally I would like the diameter of the o-ring groove as well but you don't have to remove the o-ring to measure that if it is too much trouble.
post #8 of 11 (permalink) Old 03-14-2016, 01:29 PM
Fonzi's Avatar
Ok. I should be able to get these next time I go out to the garage.
My signature:
Fonzi is offline
post #9 of 11 (permalink) Old 03-14-2016, 02:55 PM Thread Starter
TZ_280SEL's Avatar
Quoted: 39 Post(s)
Thanks fonzi
post #10 of 11 (permalink) Old 03-19-2016, 05:30 PM
Fonzi's Avatar
I didn't tear the O-ring out, but the o-ring itself was slightly narrower than the 27.01 mm diameter that my calipers said. The o-ring itself was only 26.8 mm in outer diameter.
The shaft is 46mm long before it switches to the gear.
My signature:
Fonzi is offline
