1972 280SE rough running - Page 2 - Mercedes-Benz Forum
post #11 of 14 (permalink) Old 03-20-2016, 08:20 AM
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 58 Post(s)
The 6 cylinder 280se w108 is mechanical fuel injection. The w108 4.5 is D jet. When i first bought my 6 cylinder 280 the main fuel filter in the engine bay was absolutely filthy. It was caked with dirt in the bottom of the canister. As suggested the tank screen would be worth a look and change. I also fitted an inline clear filter between the tank and fuel pump so i could monitor cleanliness. also add some protection for the fuel pump.
Good luck
Cheers John.
wroding is offline
post #12 of 14 (permalink) Old 03-20-2016, 05:53 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1762 Post(s)
6 Cylinder Injection Styles:
I don't believe the SOHC m130 engines ever came in a d-jet variant. I believe the m130 was last in 1972 cars, while the m110 dohc seems to have replaced it, a direct replacement in such cars as the w114, where the 1973 year had the w114 had the diagonal firewall supports eliminated in order to fit the m110 dohc. I believe the m110 was available in D-jet right from the start. I know the m110 was used in w116 cars, and don't believe the m130 was used in w116 cars. I also don't believe that the m110 ever went into any w108 at the factory. I believe the m110 went to k-jet at the end of 1976.
V8 cars:
6.3 are not d-jet. I'm not sure what it is but assume it is the same mechanical Bosch injection.
M116 and m117 were never used i with the older mechanical injection. They got d-jet from the start and switch to k-jet around the beginning of 1976.
So... I don't think there were ever any d-jet 6-cyl w108, and doubt there were any mechanically injected early w116.
And my w108 is a 1973. I know the w108 and w116 had some overlap, but assume it was limited to the 1973 model year, which you often can't find for a w108 despite having seen many 1973 w108 cars.
Edit:
So the important thing is that I'm pretty confident Kent's video applies.
wroding likes this.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #13 of 14 (permalink) Old 03-22-2016, 08:32 PM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
I always had the impression that 1972 was the very last year of production for108 and 109 models .
adler is offline
post #14 of 14 (permalink) Old 03-23-2016, 11:48 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 500 Post(s)
The Mercedes-Benz W108 and W109 are luxury cars produced by Mercedes-Benz from 1965 through to 1972 and 1973 in North America only.
https://en.wikipedia.org/wiki/Mercedes-Benz_W108
rumb is online now
