Engine swap on W110 for later 190 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 02-16-2016, 03:19 AM Thread Starter
Date registered: May 2012
Vehicle: 1964 220S
Hi, I have a column change 190c 1965 with a stuffed engine, will an engine from a later ( mid to late 1980's) car mate up to my 4 speed gearbox, I can pick up a complete running car for about £800 and my 190 was very slow anyway so a bit more power would be good
Thanks
Elkie is offline
post #2 of 4 (permalink) Old 02-16-2016, 05:14 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1717 Post(s)
What kind of engine? Or what car is it coming from?
What kind of skills do you have?
It's a pretty wide open question you ask.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 4 (permalink) Old 02-16-2016, 09:40 AM Thread Starter
Vehicle: 1964 220S
Sorry, I mean't another Mercedes, late 80's 190's are cheap, cheaper than rebuilding my Fintail engine so just wondered if later Mercedes engines will bolt straight up to my manual gearbox or would I need to make an adaptor plate as I'd like to retain the column change
Cheers
Elkie is offline
post #4 of 4 (permalink) Old 02-16-2016, 10:09 AM
Fonzi's Avatar
The column shifter doesn't necessarily mean you need to retain the transmission.
I am not aware of any easy direct bolt-on applications, but believe some earlier engines might be closer.
Take a look in the EPC at your transmission and engine housing or the flange / adapter plate on the engine. I did find that many late-60's-to early 80's 6-cylinder and diesel setups all used the same flange/adapter plate.
My signature:
Fonzi is offline
