W109 300SEl 4.5 Air Suspension Air Compressor Question - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 02-02-2016, 12:47 PM Thread Starter
Date registered: Jan 2009
Vehicle: 72 300sel, 61 190sl, 69 280SL
The belt on my Air suspension compressor pulley appears loose and is not fully turning the compressor and most importantly there is this loud squeeking noise coming from the pulley. It seems the pulley will turn a 180 degree turn, stop, squeey noise and turn 180 degrees stop squeeky noise. It only stops when I rev the engine, but it's the same cyle at idle turn stop squeeeeek turn stop ... at idle.
Is the belt adjustable? or can anyone give me advise? What does it take to replace the belt? Thanks, Ben
Fiams is offline
post #2 of 2 (permalink) Old 02-02-2016, 08:17 PM
Date registered: May 2015
Vehicle: 1972 300SEL 4.5
The compressor slides on a bracket that is under the compressor, there are 4 bolts that hold it on, takes 2 people, one above and one below, easier to remove the alternator as well. My old belt was stretched so I replaced it with a new one, had to remove all the other belts to get to the compressor belt. Try tighting first, much nicer when the belt doesn't squeak.
The S is offline
