Old 1972 250C Battery Terminal question - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 01-18-2016, 07:05 PM Thread Starter
billyjobs's Avatar
Date registered: Jan 2016
Vehicle: 1972 250C
When I first checked out this car it was cranking. The previous owner changed the battery. I believe the he swapped the terminals. This car was now delivered to be with no crank.
Can someone please help verify that the one closest to the front of the car connected to the chassis is negative, and the one one close to the driver side that run around to the passenger side of the engine is going to the starter and that is the positive?
If that is the case, could this have blow out the starter solenoid? or starter? from cranking?
billyjobs is offline
post #2 of 3 (permalink) Old 01-19-2016, 09:03 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
Follow the negative lead from the battery - it should bolt to the chassis within eyesight. Your car has a negative ground. Your positive lead will disappear into the guts of the engine bay (and to the starter).
Grubeguy is offline
post #3 of 3 (permalink) Old 01-22-2016, 01:43 PM Thread Starter
billyjobs's Avatar
Vehicle: 1972 250C
Thanks!
