Exploded Ignition Coil - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 12-13-2015, 08:01 PM Thread Starter
MeanGreenLoveMachine's Avatar
Date registered: May 2015
Vehicle: 1972 Mercedes-Benz 250 w114
Quoted: 2 Post(s)
Hi guys,
As I'm scrambling to get my 1972 250 ready to get running before Christmas trouble hits in the form of a fried ignition coil. The car has been sitting a while as I had the tank cleaned and install all new rubber fuel hose and a filter. Today was the day I finally got the beast to fire up. I tried to start it a couple times watching to see if the pump was drawing any fuel to the filter. After a couple of failed attempts I trickle charged the battery --which was already almost dead-- and put a little gas into the carbs just to get it the engine to fire up and start sucking gas. First try it started and immediately raced up to a high idle and oil pressure. I let it sit a little while then drove it around my loop and parked it again happy that she was running once more.
I gave it another trickle charge at 10amps and checked on it every commercial during the Eagles game. The last time I checked I came out to find the ignition coil smoking and burning plastic on the underside of my raised hood and scattered across the ground. I disconnected the battery which stopped the plastic inside the housing to stop burning. Obviously I'm going to need another ignition coil. The previous owner installed a Crane Cam 700 fireball and I'm wondering if I need to buy an ignition coil to complement this or just a bosch 12 amp coil which is similar to what was previously installed. Electrical stuff is not my forte as you can probably see. Is there anything else that I should check for a short or just replace to be safe?
Thank you!
MeanGreenLoveMachine is offline
post #2 of 16 (permalink) Old 12-13-2015, 08:06 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 459 Post(s)
did you happen to leave the ignition key on while charging?
rumb is online now
post #3 of 16 (permalink) Old 12-13-2015, 08:34 PM Thread Starter
Quoted: 2 Post(s)
Yes! Rookie mistake?
post #4 of 16 (permalink) Old 12-13-2015, 09:16 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Affirmative.
flyboyike is offline
post #5 of 16 (permalink) Old 12-14-2015, 05:09 AM
kavadarci's Avatar
Date registered: Aug 2008
Vehicle: 1971 250C
Quoted: 14 Post(s)
I have the same setup with fireball ignition, let me know what coil ahold match it as mine is factory.
Thank you
kavadarci is offline
post #6 of 16 (permalink) Old 12-14-2015, 05:26 AM
rumb's Avatar
Quoted: 459 Post(s)
That helps know what to do next. Now we know the cause and dont have to look elsewhere. New coil and look at your ballast resistor while down there and make sure it is still good also.
I learned that lesson when I was 16 years old and melted the coil in my 48 Plymouth while cruising and hanging out in the A&W drive in listening to my 8 track.....
BTW, those little trickle chargers say to use only on a fully charged battery for some reason.
anyway, glad you didn't burn your car to the ground!
rumb is online now
post #7 of 16 (permalink) Old 12-14-2015, 08:46 AM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
10 Amps isn't exactly a trickle charge! 1 or 2amps is.
Most chargers self regulate the amperage. How did you set it at 10Amps?
Anyway, the other guys seem to have sorted the main problem
1972 350SL 4.5L - MBGraham, near Kingston, Ontario
MBGraham is online now
post #8 of 16 (permalink) Old 12-14-2015, 09:35 AM Thread Starter
Quoted: 2 Post(s)
Is the ballast resistor the top box with the blue bracket in the second picture here? If so then what is the function of the bottom white/silver box that bolts in underneath it?
Also in the 1st picture what is the relay(?) with the broken plastic star knob on top. I know the plastic knob wasn't broken before this I'm just wondering if the flying piece of metal got it or if something electrocuted it to death?
Thanks everyone for the help
ID:	1707193   Click image for larger version
post #9 of 16 (permalink) Old 12-14-2015, 09:37 AM Thread Starter
Quoted: 2 Post(s)
MBGraham- I thought I could beat the system by charging it in half the time!
Lesson learned
post #10 of 16 (permalink) Old 12-14-2015, 01:28 PM
Date registered: Aug 2009
Quoted: 59 Post(s)
The cover you are asking about is a junction box.
Your original wiring set-up used both resistors. The second isn't needed with the Crane system.
You don't need the resistors if you use an aftermarket coil with the proper resistance.
The resistors were to limit voltage to the ignition contact points extending their service life.
Mike D is offline
