Sunroof not closing properly – w111 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-20-2015, 12:16 PM Thread Starter
Date registered: Aug 2011
Vehicle: w111, 220 SE, automatic, 1964
The sunroof slides well, however it does not lock properly when closed. The handle turns almost to the locked position but it will not turn all the way – missing a fraction of the turn. The sunroof almost close, but I can see it is not lifted the last 1-2 mm to be fully closed. I assume it is something with the rear part of the sliding mechanism/locking mechanism.
So my question is whether I have to remove the sunroof to get access, or is there any other issue I should/could look at before I remove it?
Einar
Fintail, sedan, 220 SE, 1964
NORWAY
Einar2 is offline
post #2 of 3 (permalink) Old 11-20-2015, 01:02 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 488 Post(s)
This guy has good kits to get you going. https://mercedessource.com/problems/...ilting-sunroof
You can use sil-glyde as a lubricant instead of the MB stuff. NAPA AUTO PARTS
I dont know W111 , but most sunroofs you remove the headliner by opening roof 1/2 way, then pull down front edge of headliner and then pull whole thing out up through opening.
rumb is offline
post #3 of 3 (permalink) Old 11-22-2015, 12:57 AM Thread Starter
Thanks, and it’s done. Rather simple to remove it and adjust the locking mechanism. However, the main reason was than previous owner had used a too long fitting screw/bolt for the chrome plate surrounding the handle – hence the handle could not be turned all the way to the locking position :-) Anyway the sliding roof need to be greased– and some minor rust spots where found. Some TLS to be done – not any major problem.
Einar
NORWAY
Einar2 is offline
