w113 280SL - Warm Running Device. - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 11-21-2015, 09:16 AM Thread Starter
Date registered: Aug 2009
Vehicle: W107 W113
Quoted: 40 Post(s)
Ok, thank you again.
So just to understand: you felt pressure against the inject pump internal spring when mounting the thermostat assembly onto the the pump?
Did you plunger have in/out free travel when you had the assembly outside the pump?
Thank you for helping - this is very critical, as if this isn't working properly the car will also be running in over rich condition.
Regards
R107
S320L1999 is offline
post #12 of 13 (permalink) Old 11-22-2015, 06:06 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
So just to understand: you felt pressure against the inject pump internal spring when mounting the thermostat assembly onto the the pump? YES. IF YOU DON'T FEEL THIS WHEN YOU MOUNT THE WRD ON THE PUMP THEN YOU HAVE A PROBLEM.
Did you plunger have in/out free travel when you had the assembly outside the pump? CAN'T ANSWER THIS QUESTION BECAUSE I ONLY TOOK THE TOP PART OFF.
SORRY I CAN'T ANSWER YOUR BASIC QUESTION.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #13 of 13 (permalink) Old 12-05-2015, 07:16 AM Thread Starter
Vehicle: W107 W113
Quoted: 40 Post(s)
Hello, I installed the WRD and did the ultimate "fire test".
I let the engine run until it was at operating temperature, and then removed the WRD air filter.
It was still pulling air from the WRD - is this normal?
Thank you
R107
