1973 280SEL Won't start - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 11-08-2015, 09:12 AM Thread Starter
KyBill's Avatar
Date registered: Feb 2014
Vehicle: 1973 280SEL 4.5
Quoted: 9 Post(s)
I tried to take video, but the sound is too faint. It appears to be coming from the starter. I tried to start with a jump, but no luck. Voltage on the battery only went down to about 11 and a half when cranking. I pulled the carpet, no access panel that I can see. I'm glad I pulled it though - found the beginnings of some rust I'll have to take care of. Every other portion of the footwell has padding that is glued down. The part isn't too bad ($138), so it's worth a shot. I'll post results when I have them.
KyBill is offline
post #12 of 15 (permalink) Old 11-08-2015, 09:17 AM Thread Starter
KyBill's Avatar
Quoted: 9 Post(s)
Mike - Just saw your post. I did try starting in neutral. I do have the three wire terminal block on the right fender well. I thought about the wiring issue, but it worked fine for a week after, and just stopped. I'm assuming it is possible something wiggled loose though. Thanks!
KyBill is offline
post #13 of 15 (permalink) Old 11-08-2015, 09:49 AM
Date registered: Aug 2009
Quoted: 60 Post(s)
Since you do have the three wire terminal on the fender well you can jump it to rule out ignition wiring.
"when cranking"? What? Do you mean when you turn the key to the "start" position.
Mike D is offline
post #14 of 15 (permalink) Old 11-13-2015, 10:49 AM Thread Starter
KyBill's Avatar
Quoted: 9 Post(s)
Update: It was the starter. Replaced and it is working fine now. Thanks everyone!
KyBill is offline
post #15 of 15 (permalink) Old 11-13-2015, 10:52 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1722 Post(s)
Thanks for reporting back. Great to know the car is running again!
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
