W110 230 Starting Problems (Electrical) - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-20-2015, 06:45 PM Thread Starter
Date registered: Apr 2007
Vehicle: 1967 230
I have a 1967 230 that is having some electrical issues. When I turn the key to start the car it starts up then dies when I release the key, if I leave the key in the start position the engine continues to run until I release the key. It will stay running if I hot wire the coil. So the coil is not getting power in the run position, but is getting power in the start position. The car ran when I parked it 10 years ago. Would this be an ignition switch issue, or a wiring issue? Is there a wiring diagram available online?
230rat is offline
post #2 of 6 (permalink) Old 10-20-2015, 09:33 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1673 Post(s)
I am not sure if the car has transistorized ignition, but I believe that one of the resistors is bypassed during cranking. Perhaps your resistor is bad.
My signature:
Click for list of my 32 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 6 (permalink) Old 10-25-2015, 11:42 AM
Date registered: Sep 2012
Vehicle: 300sel W109, 280S 70 , 220s 62. 230 66. Lancia Flavia 63.Pininfarina
Quoted: 59 Post(s)
Indicates a faulty bypass resister which can be checked for voltage on both ends, ignition on or a continuity check.
On my 230/110, I had replaced points with a Pertronix unit and still find it reliable,gives smoother idling and running .
adler is offline
post #4 of 6 (permalink) Old 10-29-2015, 07:20 PM
Date registered: Mar 2013
Vehicle: 1967 Fintail 230S
Could be the ignition switch behind the key too.
I have a similar car, and when I bought the car it had an aftermarket toggle switch installed that had to be turned on to get the car running. I think the switch is connected to the coil. It works in my car, as is, so I haven't troubled it.
Coolvibes is offline
post #5 of 6 (permalink) Old 11-08-2015, 08:37 PM Thread Starter
Vehicle: 1967 230
It ended up being the ignition switch. The electrical part was loose, so when I let go of the key the internal spring would stop at the 1 position instead of the 2 position.
230rat is offline
post #6 of 6 (permalink) Old 11-08-2015, 09:55 PM
Quoted: 59 Post(s)
How did it get rectified ,replacement or Tightening ?
adler is offline
