exhaust manifold part no - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 10-07-2015, 10:01 AM Thread Starter
Date registered: May 2015
Vehicle: 1976 450se
hi all i have an early LHD 450 se kjet and it has a crack in the leftside drivers side
exhaust manifold and searching online i am not having much success finding one.
the part no which looks most like mine is 1161421302
i took a rubbing from my one and the number is W12 MOCR 11714222901 mine looks like the attached picture which is from a RHD
any help welcome
thanks
w116john is offline
post #2 of 16 (permalink) Old 10-07-2015, 11:52 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 488 Post(s)
John, can you put your car info in your profile so we can help search? (yr/model) us or euro?
also your engine number since this is an engine part. 117/983 or 986?
rumb is offline
post #3 of 16 (permalink) Old 10-07-2015, 12:29 PM Thread Starter
Vehicle: 1976 450se
hi rumb
sorry engine no 117 986-12-003556 and vin no 11603212047677 , i had it in today at a mechanic and he says the electrics are fine, compression is good all around the 170+ number 5 a bit higher at 190, he maintains my warm start issue is leaking fuel but he recommends i replace the back box as it has a small hole and the exhaust manifold which has a crack before he tunes it checks the injectors and fuel distributor.
consequently im on the look out for a LHD exhaust manifold
thanks
john
w116john is offline
post #4 of 16 (permalink) Old 10-07-2015, 02:40 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1722 Post(s)
Where are you located?
Please fill out your profile.
I have not checked any part numbers, but I have solid single piece exhaust manifolds from two 4.5 d-jet 1972-1973 r/c107 cars. I have no clue if they might work for you.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #5 of 16 (permalink) Old 10-07-2015, 02:52 PM Thread Starter
Vehicle: 1976 450se
hi fonzi
i am in ireland , but was just advise on part numbers that i was looking for , trying to get some idea as to what part numbers would fit.
john
w116john is offline
post #6 of 16 (permalink) Old 10-07-2015, 03:36 PM
rumb's Avatar
Quoted: 488 Post(s)
EPC show 1171403909 and 1171404809, though I can quite decipher the as of engine notes. Can find a picture of either, but both show as available from the MB dealer. not sure they actually have them though.
EXHAUST MANIFOLD made by Mercedes Benz. #1171403909
rumb is offline
post #7 of 16 (permalink) Old 10-07-2015, 03:47 PM
rumb's Avatar
Quoted: 488 Post(s)
those part numbers are for a US version. do you have that or a euro? the euro has a cast iron manifold.
rumb is offline
post #8 of 16 (permalink) Old 10-07-2015, 05:02 PM
Fonzi's Avatar
From EPC per the 116 vin and engine number:
Left side for euro 117 140 48 09
(Replaced numbers 117 140 02 09 and 117 142 88 01)
:exhaust manifold part no-imageuploadedbyautoguide1444262292.949973.jpg
None of those numbers match the numbers for my early car. The d-jet heads must be different. Sorry I can't seem to help.
It is interesting (but irrelevant) to note that the right side seemed to get tri-y passenger side in later models... Like the w108 4.5.
My signature:
Fonzi is offline
post #9 of 16 (permalink) Old 10-07-2015, 05:30 PM Thread Starter
Vehicle: 1976 450se
thanks so much thats a great help , so i will have a look for 1171404809, 1171428801 and 1161421120 or equivalent
they are single pieces but the manifold on my car looks like its 3 pieces with steel connectors?
does that matter?
like this one on eBay
Mercedes W107 W116 Auspuff Krümmer 116 142 1302 | eBay
thanks
john
w116john is offline
post #10 of 16 (permalink) Old 10-08-2015, 09:42 AM Thread Starter
Vehicle: 1976 450se
i just had a look there and its a nice long crack on the inside centre of the manifold, i was thinking i might be able to get it repaired in the short term, and give myself more time to find a replacement
john
w116john is offline
