Does my 240D need to be rewired to fit this radio? - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 10-27-2015, 05:58 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 134 Post(s)
NO NO NO. the thing you have screwed into the side is one of the two front mounts that hold the face flush against the dash. That is not what goes there at all.
I think you can put the Europa bracket on the Mexico. The piece you show in the picture - you need two of those. After you have the Mexico (or Europa or any big-face Becker pinstripe radio) slide into the hole (without the chrome faceplate, knobs, dial scale on it), those long things go in the slots of the pot metal and then you screw the screw down until it holds the potmetal frame against the plastic console surround. THEN you put on the plastic dial scale and chrome bezel, then you put on the knobs.
Scoot is offline
post #12 of 12 (permalink) Old 10-27-2015, 06:19 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 517 Post(s)
The bracket in your hand goes on the front of the unit to hold it into the dash. remove the knobs and pull the faceplate off. after you insert the radio into the dash you insert them vertically into a notch and then tighten lightly the screw. knobs may have tiny set screw holding them on.
rumb is offline
