leaking fuel return - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-30-2015, 11:10 AM Thread Starter
Date registered: May 2015
Vehicle: 1976 450se
leaking fuel return
hi all
i am still searching for a solution to my boggy warm starts, and following on from reading a post from Koan on the w116.org i pressureised the system and undid the fuel return hose at the distributer to check for drips and it was dripping, i counted, and its dripping at a rate of 20 drops a minute.
it stopped dripping after about 15 minutes
my question is would that be enough to cause a boggy, low idle start for 10-20 seconds when warm?
priming the system when warm does not improve starts.
w116john is offline
post #2 of 3 (permalink) Old 09-30-2015, 03:19 PM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 1968 250S, 1991 300se, 1998 SL500, 2x 1977 450SEL 6.9. Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 405 Post(s)
read your post on 116. where is the post from koan, I could not find it.
rumb is online now
post #3 of 3 (permalink) Old 10-01-2015, 01:23 AM Thread Starter
Vehicle: 1976 450se
hi Rumb
thanks for thr reply
the post from koan was not on my thread but on a thread about a similar problem of warm starting.
when i checked the return hose , hot engine, engine off and fuel system pressurised, i had a container collecting drips and it stopped at about 50ml so probably not enough to cause a problem?
the car starts fine cold drives fine except for a mis at low revs when warm,
when warm the car takes a long time to start 5 seconds crank and then it idles very low for 10+ seconds and if i put it in drive it wants to stall, but after this it gets up to a decent idle and drives fine. i have the idle set at 850 in park and 700 in drive which helps.
i have found a mechanic who has good experience with old mercedes owning a green 450sel himself so i will give him a call today and ask him to take a look
i have probably been doing too much tinkering on this car and it needs to be set correctly
best regards
w116john is offline
