220 S "56" Mercedes - Page 2 - Mercedes-Benz Forum
post #11 of 12 (permalink) Old 10-01-2015, 06:12 AM
Date registered: Jan 2007
Quoted: 82 Post(s)
There are a bunch of bushings that can cause problems when they wear out and adjustments that you can make. Suggest you sign up for the "ponton" group in Yahoo and post your question there. There is also information on the mbzponton.org website.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #12 of 12 (permalink) Old 10-08-2015, 01:34 AM
Date registered: Oct 2010
Vehicle: Mercedes
Quoted: 9 Post(s)
It´s a common problem on these old cars, the gearbox is quite easy to fix. From my experience on benz´s, normally they get stucked inside the gear box, just need to remove the top gearbox cover, there you will find inside linkages that move the gears, those get normally stucked.
Check that first and replace bushings on outside linkages, also check steering column.
javimx5 is offline
