cleaning carbs - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 09-23-2015, 08:45 PM Thread Starter
madmanmerc's Avatar
Vehicle: 1970 250c, 300e amg
Quoted: 17 Post(s)
cleaning carbs
decided to take the carbs apart for a nice cleaning and noticed a gummy build up inside. what would be the best product to clean it off, would a varnish or even gas work. or should I use a carb cleaner. thanks jimmy
madmanmerc is offline
post #2 of 11 (permalink) Old 09-24-2015, 07:25 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
anyone......anyone......
post #3 of 11 (permalink) Old 09-24-2015, 09:01 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1754 Post(s)
cleaning carbs
I like having two if these one gallon containers. Don't leave a leather accelerator pump in there for too long.
Edit: I bought the two 1-gallon cans at walmart based on a local friend's recommendation (and because they are open so late), but see that this stuff is available at most auto parts stores like autozone, pep boys, etc.
The zenith carb parts I used these for just barely squeeze into the cans, but they do. I normally leave stuff sitting in the cans for about a week, and most of the crud comes right off with a brush. I make an effort to drip any drops of fluid back into the can before washing the part with water in the utility sink in my basement. Sometimes the part goes back in the can for a second soaking.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #4 of 11 (permalink) Old 09-25-2015, 06:01 PM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 47 Post(s)
I like using a cleaner like Fonzi shows above and put it partially disassembled in a cheap ultrasonic cleaner from Harbor Freight and you are done in 20-30 mins. A mixture of Seafoam and Valvtec Carbon Free does a good job.
Will
Baybear is offline
post #5 of 11 (permalink) Old 09-25-2015, 06:49 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
Fonzi. Are you serious? I thought 5-10 mins max. Wow. I guess seeing that gou have done it i will follow your advice. Thanks. Jimmy
post #6 of 11 (permalink) Old 09-25-2015, 07:19 PM
Fonzi's Avatar
I wasn't in a rush. You can probably use carb cleaner but you will probably use a lot of it really quickly and not get everything really cleaned out. If you are looking for the quick fix, then my method isn't the way to go.
I have a thread somewhere where I tore down the dual zenith carbs on my 1970 250c (basically a parts car I was trying to make run). It was a fun learning experience, and the carbs were really clean, but I never got the car to do anything more than drive around the block. Don't mess with to he settings too much!!
My signature:
Fonzi is offline
post #7 of 11 (permalink) Old 09-26-2015, 06:52 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 126 Post(s)
Fonzi's right. Chem dip is the way to go. partially disassemble, make sure you have a rebuild kit, and leave them in there for a day or so. They will look great.
Scoot is offline
post #8 of 11 (permalink) Old 09-26-2015, 09:44 AM
Fonzi's Avatar
And don't forget to buy the full repair kits for about $35 each. You will need new gaskets for your reassembly, maybe other parts too.
My signature:
Fonzi is offline
post #9 of 11 (permalink) Old 09-27-2015, 06:56 PM Thread Starter
madmanmerc's Avatar
Quoted: 17 Post(s)
Im worried about taking them competely aprt because i wont know how to put them back together. Can i partially take them apart and dip them. Basically take the 3 main parts and juzt dip them. Thanks jimmy
post #10 of 11 (permalink) Old 09-27-2015, 07:03 PM
Fonzi's Avatar
Take one apart at a time. Take lost of pictures. If you really get stuck, you've got the second one as an example.
My signature:
Fonzi is offline
