How do I remove the calipers off my W115?? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-23-2015, 08:31 PM Thread Starter
Kaelor's Avatar
Date registered: Apr 2015
Vehicle: 1970 W115 200/8
Quoted: 24 Post(s)
Hi everyone, I'm trying to get my right rear caliper off of my w115 200 and I need some tips on how to tackle this job. I have the ATE calipers, they seem to have some sort of locking plate that is bent on the bolts that hold it to the bracket. I tried bending it to get my socket in there but wasn't successful. Any tips on how to bend that plate and get my calipers out of the car? And also if you know how to plug that brake fluid line would be awesome, as it connects directly to the caliper no ruber hose. Any tips are welcome .
Kaelor is offline
post #2 of 4 (permalink) Old 09-23-2015, 10:05 PM
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 58 Post(s)
I use the flat blade of a screwdriver and gently tap the locking tab away with a hammer so you can get a socket on. I would probably loosen the brake line before you do anything it will make it easier when you remove the caliper. As far as plugging it you could use a zip lock bag and a rubber band.
Cheers John
rumb and Kaelor like this.
wroding is offline
post #3 of 4 (permalink) Old 09-24-2015, 06:57 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 499 Post(s)
an awl can also be used to get between the tab and the bracket to bend it away from the bolt.
go a head and let all the fluid drain out, you will need to flush and bleed the system anyway.
Kaelor likes this.
rumb is online now
post #4 of 4 (permalink) Old 09-24-2015, 03:37 PM Thread Starter
Kaelor's Avatar
Quoted: 24 Post(s)
Thanks for the tips, I'll try that this weekend
Kaelor is offline
