Rear axle bearing question. 108 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-20-2015, 07:39 PM Thread Starter
wroding's Avatar
Date registered: Mar 2014
Vehicle: 1968 280se, 1972 280se 4.5, Land Rover disco II, Triumph Thruxton, Triumph Tiger. +boring Chevy Van
Quoted: 58 Post(s)
Hi All
I wanted to clarify that the rear axle bearings rely solely on bearing grease for lubricant , not the rear diff oil. I have removed both rear axles and have the bearings and various seals and paper gasket on order. From what I have read in the manual the chamber formed between the two seals (inner and outer) has to be filled with bearing grease as does the bearing itself. Is this correct? When I removed the axles there seemed to be little to no grease on the bearings? Maybe it all run out due to gasket failure?
Thanks John.
wroding is offline
post #2 of 3 (permalink) Old 09-21-2015, 05:41 AM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 39 Post(s)
You are correct. The rear bearings have an inner seal to separate it from the dif and an outer seal to keep out dirt etc. The space between them is lubricated by bearing grease.
When I did my rear bearings, I had the same scenario. My inner seals were shot and the fluid from the differential had flushed all the grease out of the bearings.....but they were still running.
wroding likes this.
TZ_280SEL is offline
post #3 of 3 (permalink) Old 09-21-2015, 08:26 AM Thread Starter
wroding's Avatar
Quoted: 58 Post(s)
Thanks TZ.
John
wroding is offline
