M117 adjustable timing gears - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 09-20-2015, 03:41 PM Thread Starter
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
Has anyone purchased these or know if they are still available? The "contact" link does not work and I don't want to blindly send off money. I was having my own made but they will end up costing as much as these by time I am done.
adjustable cam gears for m117 motors - feind motorsports
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #2 of 15 (permalink) Old 09-20-2015, 04:11 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1679 Post(s)
Neat! I've never seen these before. Not cheap, but very neat.
My signature:
Click for list of my 32 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 15 (permalink) Old 09-20-2015, 08:33 PM
MBGraham's Avatar
Date registered: Oct 2006
Vehicle: '72 350SL, '85 300D, '98 E320, '14 GLK250
Quoted: 8 Post(s)
Haven't dealt with them, but they do have a facebook page. On it the contact info is:
Phone 979.731.8100
Email info@feindms.com
Would you be using them for performance reasons or to just to correct for stretch/wear?
1972 350SL 4.5L - MBGraham, near Kingston, Ontario
MBGraham is online now
post #4 of 15 (permalink) Old 09-20-2015, 08:55 PM Thread Starter
Quoted: 8 Post(s)
Several reasons. As part of my iron block 5.6 project I had the block parallel decked .030 and I will need to correct the valve timing. Most/all the 5.0/5.6 cams have greatly retarded cam timing for emission reasons and I want to experiment with cam timing-both difficult to do with the small range of offset woodruff keys.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
3.5 Tony is offline
post #5 of 15 (permalink) Old 09-21-2015, 04:17 AM
Fonzi's Avatar
... As part of my iron block 5.6 project
What did you bore out to make an iron block 5.6?
My signature:
Fonzi is offline
post #6 of 15 (permalink) Old 09-21-2015, 05:33 AM
Boring Cars...meh!
Nutz 4 Benz's Avatar
Date registered: Aug 2005
Vehicle: 81 280E, 84 500SEC, 87 560, 89 "300E", 91 500SL, 15 E350 4Matic Estate, 71 BMW 2002, +others
Quoted: 17 Post(s)
I think he punched out an old iron block 4.5 M117 to 5.6
http://i30.photobucket.com/albums/c328/nutz4benz/W123/6C3A9CA5-EDFF-4834-8125-34B70B20A676_zpsiyesrawz.jpg
Nutz 4 Benz is offline
post #7 of 15 (permalink) Old 09-21-2015, 06:06 AM
Fonzi's Avatar
I know this goes OT, but is the crankshaft / stroke what makes the difference in a m116 vs m117? I understand that the DOHC m119 has an shorter stroke and the AMG hybrid m117/119 DOHC 6.0 uses an m117 crankshaft for the longer stroke. I have always wondered why the very similar m116 and m117 engines had different designations despite being so similar: 3.5-4.5, and 3.8-5.0, an 4.2-5.6. Is it the stroke?
Sorry for going OT.
I hope you get in touch with the company for the very neat cam sprockets.
If it is of any help, I've got North American 4.5 and 3.8 cams (which I assume are of no interest).
I do think that custom m117 (5.0?) camshafts are available or can be made to match euro specifications. I interested, I can dig up the info. The w126 board has a lot of info on this stuff, as do the guys at Amgclassic.
My signature:
Fonzi is offline
post #8 of 15 (permalink) Old 09-21-2015, 06:47 AM
Boring Cars...meh!
Quoted: 17 Post(s)
If I recall correctly, he used a 5.6 crank, rods and pistons in the bored out 4.5 plus other machine work.
If that site selling adjustable gears is legit, I wouldn't mind those lumpy M117 cams they have there also.
post #9 of 15 (permalink) Old 09-21-2015, 08:08 AM
Fonzi's Avatar
What's the benefit of boring out a 4.5 iron block instead of just using a 5.6 alloy block?
My signature:
Fonzi is offline
post #10 of 15 (permalink) Old 09-23-2015, 01:27 PM Thread Starter
Quoted: 8 Post(s)
This is not a casual project-it has been in R&D and construction for a while. Believe me-it has been suggested many times to install a 5.6 but my goal was a more powerful, period correct(not aluminum) engine that my manual transmission fits to replace the tired 3.5 in my coupe. 4.5 owners might want to follow my route. The 5.6 has its own issues especially since the newest ones are 25+ years old and cannot be rebuilt without custom pistons and very expensive machine work. I remembered someone saying a 5.6 crank would fit a 4.5 block so I began my project and bought a core 4.5 and 5.6 engine to play with. I found the 5.6 crank fit with minor clearancing and my 3.5 flywheel fits. I had the 4.5 block sonic tested to determine if I could bore to 96.5 and found the cylinders walls minimum .25” thick. From there I had the block bored, parallel decked and blueprinted(checking crankshaft bore, etc). I had the 5.6 crank magnafluxed, mic’ed all journals, hardness checked, checked for straightness and micro polished. I had the rods magnafluxed, stress relieved, side beams polished, resized big end, rod bolts checked, balanced. I had to buy 2 5.6 engines to get 8 good “1” size pistons so all the bores would be the same size. My goal is not a “performance’ engine but by default it will have more power due to the displacement and CR increase. This build is not costing any more than a rebuild on the 3.5 would have been-maybe less if it needed pistons. The core engines were not expensive(Pick n Pull 50% off days) I will post about the top end and other specs later since that is another long story.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
3.5 Tony is offline
