Manual Swap an Automatic 1973 280 - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 09-19-2015, 06:50 PM Thread Starter
Date registered: Sep 2015
Hi, I'm new to the forum, so please excuse me if I happen to get something wrong here, but I'm looking to swap a 4 or 5 speed manual transmission to my 1973 280. I've searched google for some time now and can't seem to get a straight answer on a good procedure. Now I'm fairly good with cars and usually have no trouble working on them, it's just I don't know enough about transmissions to do this successfully quite yet. I would like some help on determining which transmission I should look for and of course clutch, flywheel, etc. Thanks!
-Karoshi209
Karoshi209 is offline
post #2 of 16 (permalink) Old 09-20-2015, 06:44 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 130 Post(s)
Is this a W108 280SE, W108 280S, W114 280, W114 280E ...?
Scoot is offline
post #3 of 16 (permalink) Old 09-20-2015, 07:58 PM Thread Starter
It's a W114 280
post #4 of 16 (permalink) Old 09-20-2015, 08:09 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1800 Post(s)
Too bad you probably aren't near Philadelphia. I pulled everything from a 1975 240d manual trans car and I'm trying to get rid of the full conversion kit:
- radiator (no trans fluid cooler)
- flange from 240d, same as m130 and m110.
- bell housing, clutch, flywheel,
Slave cylinder
- instrument cluster
- pedal assembly
There a more in the box, including all the nuts and bolts.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #5 of 16 (permalink) Old 09-20-2015, 08:11 PM
Bob's Your Uncle!
nobby's Avatar
Date registered: Feb 2005
Vehicle: The PIG -'83 280 SL 5 speed
Quoted: 1582 Post(s)
-Karoshi209
Well you shouldn't have a problem finding a mani trani to bolt up to the M110 as that engine was available in other model cars with either a 4 or 5 speed.
Originally Posted by nobby View Post
ils peuvent aller se faire mettre
www.benzypalooza.com
nobby is offline
post #6 of 16 (permalink) Old 09-20-2015, 08:21 PM Thread Starter
Believe it or not, I'm about 3 hours from Philly.
post #7 of 16 (permalink) Old 09-20-2015, 08:22 PM
Scoot's Avatar
Quoted: 130 Post(s)
I would think a manual transmission car with an M110 engine would be fairly rare in the states.
https://en.wikipedia.org/wiki/Mercedes-Benz_M110_engine
Yeah, looking at the applications for an M110 I tend to think almost all of those are going to be non-US spec cars.
But if all the parts are the same as on a W123 240D (which surprises me) then finding THAT with a manual transmission should be easy. Still I think it's probably the wrong flywheel...
Scoot is offline
post #8 of 16 (permalink) Old 09-20-2015, 08:23 PM Thread Starter
As I imagined. I just needed to make sure that the other M110's didn't have a different area where the flywheel bolted up and what not. I wanted to make sure that nothing changed. So what car do you think I could pull one of these out of?
post #9 of 16 (permalink) Old 09-20-2015, 08:23 PM
Scoot's Avatar
Quoted: 130 Post(s)
Well there you go! Fonzi, will he still need a different flywheel?
Scoot is offline
post #10 of 16 (permalink) Old 09-20-2015, 08:24 PM Thread Starter
I don't mind having one shipped from overseas. I just need to get an idea of where I can get one.
