1976 300D oil circulation problem on engine - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-18-2015, 09:21 PM Thread Starter
Date registered: Dec 2009
Vehicle: 1976 300D
Quoted: 2 Post(s)
Send a message via Yahoo to amarbenj
i noticed the "noisy" engine one time. the oil pressure gauge on the instrument cluster is functioning. but it seems that the oil doesnt circulate anymore on the engine. i opened the hood and and remove the valve to check if the oil circulates. it seems in the negative. what went wrong?
when the oil pressure gauge on the instrument cluster is working, does it mean the oil pump is ok?
kindly help.
thanks.
amar
amarbenj is offline
post #2 of 5 (permalink) Old 09-19-2015, 11:26 AM
Date registered: Jul 2008
Quoted: 352 Post(s)
What does the oil pressure gauge read? Does it drop? I am thinking your thrust bushing has went bad...thus the oil pump is only working sometimes...
Check out the thread I made...
Clank Clank when cold....new engine time?? - Page 2 - PeachParts Mercedes ShopForum
amarbenj likes this.
cooljjay is online now
post #3 of 5 (permalink) Old 09-27-2015, 06:51 PM Thread Starter
Vehicle: 1976 300D
Quoted: 2 Post(s)
it actually started after that "bad hit" over a big rock that almost pressed my oil pan.
after which, oil no longer circulates on the engine. but the oil pressure gauge is functioning when i first started the engine in the morning.
i removed the oil pump and cleanse it with just a diesel fuel. i tried rotating the shaft on the top end point and it seems ok. i removed the screen and found some particles of metal on it. i reinstall it and change oil. but still, i noticed that the oil did not circulates after running it for 3-5 minutes. Worse, the engine shut off. when i restarted it, i heard a more louder noise on the engine but it no longer starts even after i change the oil.
my 1976 300D is my first car. i have no budget to replace the engine or buy a new car. If my 300D will not run, i will be depriving my family with some family travel on weekends. i really wanted to fix it. but i dont know the problem after that BIG HIT.
please help me. i really need your help. kindly give me a detailed work to do.
SALAMAT PO ASIN DIOS MABALOS SAINDO GABOS. (thank you and God Bless you all)
AMAR(Philippines)
amarbenj is offline
post #4 of 5 (permalink) Old 09-28-2015, 11:16 PM Thread Starter
Vehicle: 1976 300D
Quoted: 2 Post(s)
Hello there!
May i request your expertise on this matter please.
Was that "big hit" already the end of my 300D?
please help me.
thanks.
amar
amarbenj is offline
post #5 of 5 (permalink) Old 09-28-2015, 11:20 PM Thread Starter
Vehicle: 1976 300D
Quoted: 2 Post(s)
Hello there!
please help me.
thanks.
amar
amarbenj is offline
