How to bleed the clutch of a w115? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-18-2015, 09:06 PM Thread Starter
Date registered: Jun 2009
Hi Everyone!
Didn't use my w115 200d for a couple of months and the gears won't engage now. I suspect that there's some air in the clutch system but I don't know where to start to bleed the system. Would greatly appreciate it if someone could point out to me the location of the bleed nipple. I could work it out from there. Thanks always!
ijiwaru is offline
post #2 of 3 (permalink) Old 09-19-2015, 11:39 AM
Date registered: Jul 2008
Quoted: 352 Post(s)
You'll probably need to rebuild the slave and master clutch cylinders. But the nipple for bleeding is on the slave clutch, which is on the side of the transmission. You will need to reverse bleed the clutch aka pump the brake fluid from the bottom up. An old metal oil can works great.
Where is the clutch bleed screw? - PeachParts Mercedes ShopForum
http://www.benzworld.org/forums/w123...ed-clutch.html
cooljjay is offline
post #3 of 3 (permalink) Old 09-19-2015, 06:21 PM Thread Starter
Thanks, Cooljay!
ijiwaru is offline
