Temperature switch for 1972 250 - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-15-2015, 08:30 AM Thread Starter
Date registered: Jun 2013
Vehicle: 1972 Mercedes 250
Hi guys, I ordered what the EPC says is the right temperature switch, part number 0035452224 but on the EPC it says its 65 degree but the one I received is 70 degree.
Whats going on here?
Thanks
Emilea709 is offline
post #2 of 3 (permalink) Old 09-15-2015, 11:37 AM
Date registered: Aug 2009
Quoted: 59 Post(s)
Temperature switch for what?
The vacuum changeover solenoids? (Vacuum advance for distributor/chokes)
If so then the 70C one is the proper one (158F). Nothing wrong with using either one. Difference of only 9 degrees and the 70C one is more in line with the accepted 160F level used most often as minimal operating temperature.
Mike D is offline
post #3 of 3 (permalink) Old 09-16-2015, 07:13 PM Thread Starter
Hi Mike, Thanks for the reply. The part I'm replacing on my car is thermo switch on the head just before the 6th cylinder and the one I bought to replace it is a 70 degree and has a different connection. I was just going to change the plug on my car to the right plug to fit the new switch, will that work ok do you know?
Thanks so much.
ID:	1612473   Click image for larger version
ID:	1612481   Click image for larger version
