w108 1972 280sel power window nightmare - Mercedes-Benz Forum
post #1 of 12 (permalink) Old 09-08-2015, 07:28 AM Thread Starter
mcwcustoms's Avatar
Date registered: Dec 2014
Vehicle: 1972 280SEL 4.5
Exclamation w108 1972 280sel power window nightmare
Hi everyone,
Just started putting together my inteior on a long restoration.
Power window motors were taken out and lubbed two regulator changed.
All terminals cleaned and lubbed
Now to the issue.
My front driver and rear passanger windows work perfect, BUT my front passanger and rear drivers windows do not.
Checked power on the NOT working switches and they do have power and ground but instead of reversing polarity they change polarity all together to the motor either sending both positive or both negative, that goes to both doors that are not functional.
The relays were checked, fuses checked
No wiring was ever cut or looks to be cramped anywhere, probed both motors w reverse polarity they work perfect bypassing the system.
I am pretty savy at wiring but this is kicking my butt.
Any help welcome.
Thank you in advance
mcwcustoms is offline
post #2 of 12 (permalink) Old 09-08-2015, 08:26 AM
Date registered: Nov 2008
Vehicle: 1981 300TD 310k--1966 230 165k--1970 280se 172k
Quoted: 36 Post(s)
My experience with these Mercedes power windows indicates that 90% of the problems are in the switch. Especially when you get alternate side problems front and rear. Either take them apart and clean the contacts or buy another switch.
1981 300TD--310k miles
1970 280sel--172k miles
1966 230--162k miles
carpenterman is offline
post #3 of 12 (permalink) Old 09-08-2015, 09:47 AM Thread Starter
mcwcustoms's Avatar
The windows were flawlessly working before the resto thats why never bothered w the switches, going to check them now thank you Carpenterman!
post #4 of 12 (permalink) Old 09-08-2015, 04:49 PM Thread Starter
mcwcustoms's Avatar
Just a update tried new window switches and they did not work.
This is very frustrating, anyone have a wire diagram for the rear door switches the numbered plugs?
post #5 of 12 (permalink) Old 09-08-2015, 07:57 PM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 37 Post(s)
See if this helps.
Will
Baybear is offline
post #6 of 12 (permalink) Old 09-08-2015, 08:27 PM
Date registered: May 2015
How do you roll the windows down by bypassing the switches? I have problems with all of mine and I just need to get some air! I have the drivers door panel off, and I see the wires, but I dont know how to use them to trigger the window moter. I would reaaly appreciate any help, I drive an hour to work everyday and it is litteraly killing me.
Originally Posted by mcwcustoms View Post
Hi everyone,
Now to the issue.
Any help welcome.
Rizioule is offline
post #7 of 12 (permalink) Old 09-08-2015, 08:34 PM Thread Starter
mcwcustoms's Avatar
You should have two wires, you must supply (-) negative to one wire and (+) positive to the other in order to actuate the motors. Reversing the order (polarity) will make it go up or down.
post #8 of 12 (permalink) Old 09-08-2015, 08:50 PM Thread Starter
mcwcustoms's Avatar
Originally Posted by Baybear View Post
See if this helps.
Will
Thank you Baybear,
What chassis is this diagram for?
post #9 of 12 (permalink) Old 09-09-2015, 09:05 AM
Quoted: 37 Post(s)
Looking at the diagram it appears this is supplement 3 for the early window motors that used 3 connections which were used from August 1965 up to May 1969. I assume you need the later one which used 2 connections. That should be shown in the "regular" wiring diagram. I can send it to you tonight or if you have the Big Blue Book, Service Manual Passenger Cars starting 1968, Series 108-109-111-113, Maintenance, Tuning, Unit Replacement it is in there.
Will
Baybear is offline
post #10 of 12 (permalink) Old 09-09-2015, 04:26 PM Thread Starter
mcwcustoms's Avatar
Will
ISSUE SOLVED!
Thank you Baybear, it was the connection in one of the front fuses that was broken inside the fuse box.
After a continuity check the fuse was ok, and the wire going forward was ok, but the connection between the wire and fuse holder was not.
What a mission just glad it is working
Thank you again for all the help
