1971 250 Fuel Pump Question - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 08-04-2015, 10:04 AM Thread Starter
dgosh28's Avatar
Date registered: Oct 2011
Vehicle: '71 250, '78 450SLC 5.0, '78 450SL, '81 380SLC 5.6, '89 260E, '15 Kia Sorento
Quoted: 103 Post(s)
Hi All,
I've been away awhile, but still making small gains with my W114. The car had been running well the past couple of months, after it left me stranded for an hour a couple of months ago. Well, Saturday before last the car decided to die and not restart. I had it flat bedded home and of course it fired right up once in my driveway. I finally decided to install the new fuel strainer that I'd bought 2 months ago and I moved the fuel filter to the carburetor side of the fuel pump from the inlet side. Now for my question, I suspect my fuel pump may be getting weak so I want to replace it. The problem is, I have the style that has a 90 degree shaft on it and all the online vendors sell a different style. Can anyone tell me what the difference is and where I can get the correct part? Even the EPC shows the part number for the straight shaft model, which Fonzi was kind enough to give me, but it doesn't match the one on my car. Any help/advice is welcome.
Dan
dgosh28 is offline
post #2 of 14 (permalink) Old 08-04-2015, 11:23 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1716 Post(s)
Vin: 114.011.12.003097
Picture of Dan's current pump:
EPC part number: 115.090.01.50
AutohausAZ part number for 1971 250: 115.090.01.50
Picture of autohausaz pumps:
Picture of "new" pump in a vaico that had 115.090.01.50 part number on it that I found in trunk of my 1971 250 and gave to Dan:
Picture of pump Dan found by googling w114 fuel pump:
I think Dan's question is where to find the fuel pump in the last picture, and what it's part number should be.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 14 (permalink) Old 08-04-2015, 11:30 AM
Fonzi's Avatar
Apparently not a place to buy, but I have yet to find where the WorldPack picture came from. If you can give that part number to your mechanic, he can surely order from WorldPac
http://fautoparts.com/body-Fuel-Pump...3.0-auto-parts
My signature:
Fonzi is offline
post #4 of 14 (permalink) Old 08-04-2015, 01:38 PM Thread Starter
dgosh28's Avatar
Quoted: 103 Post(s)
Thanks Fonzi. I think WorldPac is owned by Advance Auto Parts now. Maybe it's the other way around.
dgosh28 is offline
post #5 of 14 (permalink) Old 08-04-2015, 02:00 PM
Fonzi's Avatar
Ask Sam if you need a Pierburg.
My signature:
Fonzi is offline
post #6 of 14 (permalink) Old 08-08-2015, 05:14 AM Thread Starter
dgosh28's Avatar
Quoted: 103 Post(s)
Now I have fuel pouring out of the vent on top of the rear carburetor. I've pulled the top two pieces off the carburetor so I can check the float adjustment. Hopefully that will fix the problem.
dgosh28 is offline
post #7 of 14 (permalink) Old 08-08-2015, 06:23 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 477 Post(s)
That style pump is nla. It either works or it doesn't, there is no in between. I found vendor on ebay that sold repair kits, that worked with modifications. You only need if the diaphragm breaks.
rumb is offline
post #8 of 14 (permalink) Old 08-08-2015, 06:26 AM
Fonzi's Avatar
The float valve must not be working or the float is sticking. The valve is part of a repair kit, and probably should have been replaced with the rebuild on your carbs. Taking a look at your spare carbs on the shelf might help you understand what's going on.
It might also be worth checking the fuel return valve on the front carb to make sure it's allowing fuel back to the tank.
My signature:
Fonzi is offline
post #9 of 14 (permalink) Old 08-08-2015, 06:43 AM
Fonzi's Avatar
Dan,
This may be the answer to the query of whether your pump is a problem. It sounds like your pump probably isn't a problem. Maybe replacing the fuel tank screen and putting the filter on the carb side of the pump will solve your problems... at least until some bits of rust get into a tube in the fuel tank. Keep the tank full when venturing away from home in case there are some tubes on the bottom of your tank that are clogging.
My signature:
Fonzi is offline
post #10 of 14 (permalink) Old 08-08-2015, 06:55 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 121 Post(s)
re: piersburg fuel pumps, autohaus, MB, other sellers... I replaced what I think is the same fuel pump in my 63 220S. I went through 3 fuel pumps from Autohaus and others and they all leaked. I finally bought one from the Classic Center that looks exactly the same and it doesn't leak. I have no explanation for this, but it is not inconsistent with others who have reported weaping fuel pumps that are new.
Scoot is offline
