W114 rocker arm spring issue - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 07-23-2015, 02:32 PM Thread Starter
Date registered: Jun 2013
Vehicle: 1972 Mercedes 250
When I removed the valve cover on my 1972 250 sedan,
I noticed one of the springs was out of place on one of the rocker arms and very loose and doesn't stay in place when you put it back in its just kind of layed there.
Any idea how I would go about fixing this?Is this a valve clearance issue? and what kind of symptoms would fixing this alleviate?
Thanks so much for helping me along guys!
Name:	rocker arm issue.jpg
Emilea709 is offline
post #2 of 4 (permalink) Old 07-25-2015, 09:42 AM
Date registered: Jan 2007
Quoted: 85 Post(s)
The springs are supposed to help hold the rocker arm against the cam and reduce "slap" that could cause wear and noise. I have never seem one slip off like this. It could be that the spring has lost its tension, or something is wrong with the groove in the rocker.
It should take a fair amount of force to get the spring on the rocker. If it doesn't, replace it. If it does, then replace the rocker.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #3 of 4 (permalink) Old 07-27-2015, 05:44 PM Thread Starter
I believe the groove in the rocker is worn, I have a spare luckily. Thanks so much for the response.
post #4 of 4 (permalink) Old 07-27-2015, 05:59 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1677 Post(s)
I see the spring to the right seems to be centered on the rocker arm. I just pulled the valve cover from an m130 and noticed that a few springs were also off center. I'm not yet aware of whether they are under tension or not though. (The engine is seized.)
My signature:
Click for list of my 32 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
