1965 220se - Page 3 - Mercedes-Benz Forum
post #21 of 21 (permalink) Old 08-02-2015, 10:29 AM
Date registered: Jan 2009
Vehicle: anywhere from '52 300 to 1990 560SEL,and a '93300TE nothing newer, too much trouble....
Quoted: 16 Post(s)
Originally Posted by 220sejoey View Post
Alex,
I am in Rancho Cucamonga, Ca. Scoot thanks for the link. I will take notes.
I do not know the last time the car ran. It sat in a garage for many years waiting to be revived. I was to that the car had fuel injector issues and a short that would drain the battery. In the short time I have spent in the car, I have found that the fuel pump does not work. I have yet to test the leads. I may just grab a test and check back in later.
FYI,
the wiring is usually the very least of your problems.
If it's still connected, then chances are the pump worked last time the car ran.
BUT several years later from sitting the gas has turned into varnish in the tank and most likely dried up in the pump, therefore freezing it !
I have seen it many times.
Good Luck
Alex
6punkt3 is offline
