Question about engine oil - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 07-17-2015, 09:55 PM
Date registered: Jul 2010
Vehicle: '85 300D Turbo, '91 420SEL, '92 190E 2.6, '09 C350, '12 E63 Wagon
Quoted: 183 Post(s)
Originally Posted by HeckflossePilot View Post
Years ago Richard Lentinello, over at Hemmings, replaced mineral oil with synthetic in a used car. The synthetic soon loosened up old carbon deposits in the nooks and crannies of the engine, clogged the oil filter, went through the filter by-pass and wiped out his bearings. If replacing mineral oil with synthetic, at the very least I would pull the cam cover and check the cleanliness of the engine, but as a rule of thumb, I wouldn't replace one with the other without a engine re-build and thorough cleaning.
This may be a concern.
carpenterman: If you believe that, then you must believe that of yourself. If oil can't be improved, then why is it you can do a 10k mile change nowadays, just increased volume?
OP asked if it's okay to use the oil. If the car is in good shape and has been well maintained, then the answer is yes.
jzchen is online now
post #12 of 16 (permalink) Old 07-18-2015, 05:35 AM
ejboyd5's Avatar
Date registered: Jun 2009
Vehicle: 1955 300 SL
Quoted: 90 Post(s)
Quite a discussion over 5 liters of motor oil sitting in a jug in Peru. Does anyone know if it is a synthetic blend or is "Synergie+" simply a trade name?
Kaelor likes this.
ejboyd5 is offline
post #13 of 16 (permalink) Old 07-18-2015, 06:51 AM
Date registered: Aug 2009
Quoted: 60 Post(s)
Oil, antifreeze/coolant and or refrigerant topics are always good for a couple of pages of posts.
Kaelor likes this.
Mike D is online now
post #14 of 16 (permalink) Old 07-19-2015, 01:42 AM
Quoted: 183 Post(s)
Seems like synthetic blend:
https://www.motul.com/ca/en-US/produ...synergie-10w40
post #15 of 16 (permalink) Old 07-21-2015, 09:24 AM Thread Starter
Kaelor's Avatar
Date registered: Apr 2015
Vehicle: 1970 W115 200/8
Quoted: 24 Post(s)
Ok so I was busy these past few days with work, studying, gf and also trying to get a new job at a Mercedes dealer hehe. I see this post has reached two pages already, nice to have all this info. To clarify, I'm rebuilding the entire engine and you can say the whole car also. The engine has no oil and hasn't had any for a few years now, so there is no situation of mixing oils and I'm replacing all seals and bearings so no issue there either. I'm cleaning the engine thoroughly and all the parts of it and want to leave no carbon behind.
About the oil, I just realized it's semi-synthetic and not a 100% synthetic. The temp range it's good for the engine, also it's a gasoline engine not a diesel.
Would this oil be good or better than mineral oil? If anything at least serve it's job normally in my engine?
Kaelor is offline
post #16 of 16 (permalink) Old 07-22-2015, 09:34 AM
Date registered: Jun 2015
Vehicle: 1978 280SE
I would not hesitate to use this in a fresh engine, but you may want to get more expert advice on breaking in a newly re-built engine with synthetic or synthetic blend oils. You'll also want to do an oil change within 500 miles to get the assembly lube out of there and break open and inspect the oil filter for any metal shards.
Kaelor likes this.
HeckflossePilot is offline
