w108 Door Cardboard Material - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 07-12-2015, 12:24 PM Thread Starter
Date registered: Jun 2009
Vehicle: 280SE 3.5
Hi everybody,
Recently I'm dealing with my w108 door cardboards. As they get soften and damaged over time, I'm thinking of replacing them but not sure about which material cardboards are made of? Masonite or MDF? Anybody has any idea? Thickness about 5mm I guess..
Regards
Kutluhan
Jazzenco is offline
post #2 of 7 (permalink) Old 07-12-2015, 02:03 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
I would go with ABS sheet material something like this:
ABS Plastic Sheet Textured General Purpose Haircell Finish
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
post #3 of 7 (permalink) Old 07-12-2015, 02:25 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 499 Post(s)
go to a upholstery shop and buy wax board / black board. They make door panels with it all the time.
rumb is offline
post #4 of 7 (permalink) Old 07-13-2015, 01:20 PM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 39 Post(s)
I built mine for my W108 5 years ago. I used standard old 3/16" hardboard from Home Depot. I removed mine a few months ago to do a conversion to power locks. No issues at all. I made sure to cover the openings in the inner door skin with plastic to keep any rain water from wetting the hardboard.
I put smooth side to the door. I put a small amount of batting on the interior side and covered in MB TEX. Used the old ones as a template.
Name:	door cards.jpg
TZ_280SEL is offline
post #5 of 7 (permalink) Old 07-13-2015, 02:22 PM
Date registered: Aug 2009
Quoted: 66 Post(s)
Next time, make sure you have the instruction page turned right side up! Although, this method does appear to be the solution to how to keep the ash trays from being used.
Mike D is offline
post #6 of 7 (permalink) Old 07-13-2015, 05:22 PM
TZ_280SEL's Avatar
Quoted: 39 Post(s)
Not sure why it did that, but looked good in the preview post. Anyway, if you lock your screen and turn it upside down, looks right
post #7 of 7 (permalink) Old 07-14-2015, 04:06 AM Thread Starter
Vehicle: 280SE 3.5
Thank you very much for replies. I will check for all hardboards, waxboards and ABS sheets. Just worrying how to open holes for mounting clipsi ashtrays and window switch..
Jazzenco is offline
