1967 250SE cupe - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 06-30-2015, 12:22 AM Thread Starter
Date registered: Jun 2015
1967 250SE cupe
hello, please give me an advise:
Im restoring my 1967 250SE M129 engine cylinder head. Now its time to put everything back.
I install new timing chain and have engine crank on 0 and the cam mark in line with mark on tower. Distributor rotor pointing at #1 . Now I have to install the injection pump. Do I have to rotate engine to 20* ATDC ( it means to number 2 on crank?) and than install the injection pump?
please help me to do the right job.
thank you
GARY67 is offline
post #2 of 3 (permalink) Old 06-30-2015, 06:56 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1465 Post(s)
I recently swapped out an injection pump on this exact engine, and seem to recall setting the crank to 20 degrees ATDC, but my memory is fuzzy with old age. I used the instructions supplied by the pump remanufacturer. Try searching for tech specs here
Pagoda SL Group Technical Manual :: Engine / TimingChain
Zeitgeist is offline
post #3 of 3 (permalink) Old 06-30-2015, 10:21 AM
Date registered: Jan 2007
Quoted: 82 Post(s)
Correct. Then line up the mark on the pump gears with the mark on the case and install the pump.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
