W108 280se engine head swap - Mercedes-Benz Forum
post #1 of 15 (permalink) Old 06-26-2015, 11:02 PM Thread Starter
Date registered: Jun 2015
I have a 1970 280se 6cyl fuel injected, I bought a second hand head from a 280s and had it reco'd cost me a bit, now that I've spent all this money, I realize that the heads are slightly differnt eg combustion chamber is different and so is the thermo sensor inputs. My question is can I make the 280s head fit my 280se engine??? I'm having heaps of drama with this car ?
Everard is offline
post #2 of 15 (permalink) Old 06-27-2015, 01:57 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1721 Post(s)
I am very sorry to say.... It sound like you have decided to come to this site way too late if this car has been causing you frustration.
The "e" in a MB name represents a fuel injected gasoline engine. When the injection or intake system is different on an engine, usually the heads are different too.
There are tools you can use like the EPC, and people at your local MB dealer or the classic center that are often willing to help, and even more willing people on this website.
I am sorry for your frustration, but someone with a carbeurated car might be interested in your newly refinished head.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #3 of 15 (permalink) Old 06-27-2015, 03:24 PM
rumb's Avatar
Date registered: Oct 2012
Quoted: 488 Post(s)
try contacting the seller of this head on fleabay, as they appear to be knowledgeable about head interchanges.
Mercedes M130 Cylinder Head 1300102421 | eBay
rumb is online now
post #4 of 15 (permalink) Old 06-27-2015, 03:39 PM Thread Starter
Hi guys thanks for your response, both heads are indeed fuel injected. I bought the head off a Bloke who has stripped 200 of these cars he told me I can fit a newer head on an older engine but not an older head on a newer engine. He still managed to sell me a slightly older head..... I will try and post photos later today for better understanding.
Everard is offline
post #5 of 15 (permalink) Old 06-27-2015, 04:13 PM
Fonzi's Avatar
280s is a carbeurated engine, not fuel injected, pretty sure both 280s and 280se (with no number afterwards) are both m130 2.8 engines. I don't know what else to say unless someone can prove to me otherwise.
My signature:
Fonzi is offline
post #6 of 15 (permalink) Old 06-28-2015, 06:24 AM
rumb's Avatar
Quoted: 488 Post(s)
dont know if this is useful to you or not
Pagoda SL Group Technical Manual :: Engine / CylinderHead
rumb is online now
post #7 of 15 (permalink) Old 06-28-2015, 04:52 PM
Date registered: Jan 2007
Quoted: 85 Post(s)
It's really easy to figure out. If it's an injected head, it will have six threaded holes for the injectors on the intake (right) side of the head.
Chuck Taylor
Falls Church VA
1998 SL500
1959 220S
1970 280SL
ctaylor738 is offline
post #8 of 15 (permalink) Old 07-10-2015, 11:05 AM
Vehicle: 2000 ML320, 2005C240 4matic wagon, 1962 220SEb, 2002 CLK55 Cabrio, 2014 C300 4matic, 2000 CLK55
Quoted: 2 Post(s)
The older heads from the earliest 220SE motor had a 2 element fuel injection pump that fed through the intake manifold by way of a system of dividers.
The intake manifold had very long runners.
This head did not have the ports machined directly into the combustion chamber.
Later 6 element pumps had the port in the head and used a shorter intake manifold
yaki b is offline
post #9 of 15 (permalink) Old 07-10-2015, 01:26 PM
Fonzi's Avatar
How about the blocks? Last night a friend told me the 280s block won't work in a 280se (or a 280se head won't work on a 280s block). Is that true?
My signature:
Fonzi is offline
post #10 of 15 (permalink) Old 07-13-2015, 04:35 AM
Quoted: 2 Post(s)
The 280s block has no provision for the oem mechanical FI pump.
The 280se head could work on a 280s block but you will need to plug the injector ports and may require an adapter for the heater hose outlet.
yaki b is offline
