W108 280se engine head swap - Page 2 - Mercedes-Benz Forum
post #11 of 15 (permalink) Old 07-13-2015, 05:09 AM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Vehicle: slc5.0cab 280sl5sp 280se4.5 500sl92 GONE:280sl79 4xW114/5 3x450sl72-3 280slc4sp81 280s69 73,81SLCs
Quoted: 1569 Post(s)
Originally Posted by yaki b View Post
The 280s block has no provision for the oem mechanical FI pump.
The 280se head could work on a 280s block but you will need to plug the injector ports and may require an adapter for the heater hose outlet.
To clarify... It looks like you are saying that maybe the 280se (injected) head might be able to work on a 280s engine block, but in a carburetor setup, not a fuel injected setup. Correct?
If the oem mechanical fuel pump is the only issue with using a 280s lower end in a 280se, might you be able to simply use and an electric fuel pump? Too dangerous?
My signature:
My dream car is a classic sporty five speed (stick+overdrive) convertible that seats five. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #12 of 15 (permalink) Old 07-14-2015, 04:07 AM
Vehicle: 2000 ML320, 2005C240 4matic wagon, 1962 220SEb, 2002 CLK55 Cabrio, 2014 C300 4matic, 2000 CLK55
Quoted: 2 Post(s)
Clarification is correct.
The oem fuel pump is a complex devise that precisely meters and distributes the fuel to each cylinder and is rotated by an additional gear from the timing chain.There is an electric fuel pump that supplies the fuel from the tank to the mechanical pump.
The term "simply" is not to be used when discussing this era of mechanical fuel injection.
yaki b is offline
post #13 of 15 (permalink) Old 07-28-2015, 06:26 PM
Date registered: Nov 2012
Vehicle: 84 300 DT, 69 280 SE Cp low grill, 09 C 300, 68 280 SE, 2 350 SL 4 sp, 65 220 SEb Cp, 92 500E
I am under the impression that there are 2 versions of the 280 SE injected head. Correct?
I was told that a early version head will not work on a later version block
Would a later version head work on the early block?
Thanks in advance for your help
rockingchairmotors is offline
post #14 of 15 (permalink) Old 07-28-2015, 09:11 PM
drew56cus's Avatar
Date registered: Oct 2006
Vehicle: 1965 220SE sedan (finnie) with 450SE conversion, 1964 220SE coupe project, 1966 300SE coupe
Quoted: 32 Post(s)
Gee I vaguely remember stuff about this when I encountered it last year. Something about square combustion chamber (old) vs round (newer). IIRC you could the later head onto the early block, but needed to hammer a thin piece of copper wire into a thin water jacket slot to block it off as the early head did not have the water jacket.
Hopefully this will jog someone elses memory otherwise I will have to go to my mates house to get the spare head and look at it again.
drew56cus is offline
post #15 of 15 (permalink) Old 07-29-2015, 08:36 AM
I looked up some info on the Pagoda site and a few people there claim that they are not interchangeable.
I was sure that a later version head would fit on a early block. Again we are just talking 280 SE M130
Does anyone have first hand experience with this?
