Question about engine swaps ¿? - Page 3 - Mercedes-Benz Forum
post #21 of 25 (permalink) Old 06-24-2015, 11:54 AM Thread Starter
Kaelor's Avatar
Date registered: Apr 2015
Vehicle: 1970 W115 200/8
Quoted: 24 Post(s)
Cosworth is not an option here since there may be only one or two of those mercs that came with it in my country. I know about one but haven't heard about other.
I might pick up one of those models you talk about in the future, that or a BMW haha.
Kaelor is offline
post #22 of 25 (permalink) Old 06-24-2015, 12:18 PM
Date registered: Oct 2013
Vehicle: 1982 240D, 1984 Euro 300TD
Quoted: 36 Post(s)
Originally Posted by Kaelor View Post
20+ mpg is that true?? that's a good number. And about the v8, I guess I should consider that too but the mods I would have to do would be greater than fitting a 6 cyl on the W115.
I will look at that transmission replacement. If I can find one I might do it but it's kinda hard to find one of those here.
About the stell struts you talk about, are those the ones in the pic below?
Yes.
I know the carbed M110 were fitted to these bodies, but a V8 might be tight in there.
So far as fuel economy, my M130-powered '72 25O used to manage 20+ mpg on the highway if I didn't push it hard, my Fintail 230-6 about the same, and my M115 '72 220 maybe 1-2 mpg better. All usually ran in the low to mid-teens in city driving. Both were automatics. I'd expect maybe 1-2 mpg better overall with a stick-shift.
A taller rear-end gear could make a significant mpg improvement on the highway. But in the US we got a shorter gear (4.03 vs 3.92 outside the US) to improve acceleration on cars that cost a lot more than the typical American V8.
Happy Motoring, Mark
Mark DiSilvestro is offline
post #23 of 25 (permalink) Old 06-24-2015, 01:01 PM
Date registered: Aug 2009
Quoted: 59 Post(s)
W115's never had a M110. '73 and later W114's had the M110 (no cross braces). I believe the O.P. said he didn't want to remove the braces which eliminates the possibilities of either the M110 or M117.
Kaelor likes this.
Mike D is offline
post #24 of 25 (permalink) Old 06-24-2015, 02:08 PM Thread Starter
Kaelor's Avatar
Quoted: 24 Post(s)
Yes the W115's were fitted only with 4cyl gasoline engines and 4 and 5cyl diesel. The W114 line got the bigger engines.
I'd rather not cut anything off my car unless I really need to. The M130 seems like an easy swap in comparison if the I4 fails.
Thanks for all the info .
I just wanted to know if the tranny of the M130 is the same tranny that came with the M115. It's the 722.1 I think.
Kaelor is offline
post #25 of 25 (permalink) Old 06-25-2015, 01:32 AM
Quoted: 36 Post(s)
In my original post, I didn't say the M110 was used in the W115.
I've since re-edited to make my meaning clearer - that the M110 was used in essentially the same body shared by the W114 - at least same enough if one is considering swapping parts.
