White Smoke! Fuel sensor? - W108 280SE 4.5 - Mercedes-Benz Forum
post #1 of 27 (permalink) Old 06-14-2015, 01:40 PM Thread Starter
Date registered: Apr 2014
Vehicle: 1972 280SE 4.5
Quoted: 5 Post(s)
This sensor shown in picture below doesn't do anything?!
I have problem with engine that makes a lot of white smoke! So I am thinking it is problem with Fuel system.
When I unplug this plug while engine is running, no changes happen to the way engine is running.
I took measurements at the sensor and it gave 4.6 Ohm. Is this normal? what could be the problem?
Many thanks,
Name:	Fuel sensor.jpg
fzbenz is offline
post #2 of 27 (permalink) Old 06-14-2015, 03:46 PM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 70 Post(s)
Not sure I agree with your detective work there...white smoke usually indicates coolant getting into the combustion process somewhere.
fzbenz and RedtailPDX like this.
flyboyike is offline
post #3 of 27 (permalink) Old 06-14-2015, 04:50 PM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 39 Post(s)
The "sensor" you have labeled is NOT a sensor. It is the cold start valve. Think of it as a choke if you are of a carbureted mind. Once warm, it should be closed and stay that way.
Fonzi, fzbenz and RedtailPDX like this.
TZ_280SEL is online now
post #4 of 27 (permalink) Old 06-14-2015, 07:45 PM
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1837 Post(s)
Diagnose your smoke type:
http://www.aa1car.com/library/problem_engine_smoke.htm
Bill A and fzbenz like this.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #5 of 27 (permalink) Old 06-15-2015, 07:08 AM
Bill A's Avatar
Date registered: Jan 2009
Quoted: 27 Post(s)
The cold start valve in no more than another injector and only sprays when the starter is engaged. There are two engine sensors, one is the intake air sensor in the air filter housing and the other is the water temp sensor that is installed in the intake manifold. This engine enriched the fuel based on temperatures in the cooling system/ engine water temp and the air is via a temperature sensing thermostat that allows more idle air when the water temp is below a certain value, it is located in a flat top round housing just inboard of the temp spray valve.
fzbenz likes this.
Bill A is offline
post #6 of 27 (permalink) Old 06-15-2015, 08:48 PM Thread Starter
Quoted: 5 Post(s)
Thanks a lot guys! I am learning new things everyday from this great site.
I guess I will have to check me cylinder head gasket for coolant leak, cause I don't think there is any crack on intake manifold.
Some friend was telling that the ignition power distributor could have a role in bad engine firing and possibly cause smoke. Do you agree?
Any link in regards to changing head gaskets on W108, M117 would be greatly appreciated.
fzbenz is offline
post #7 of 27 (permalink) Old 06-16-2015, 04:10 AM
Fonzi's Avatar
It is possible that wobble in the distributor could cause bad spark, which would probably result in black smoke out the exhaust.
fzbenz likes this.
My signature:
Fonzi is offline
post #8 of 27 (permalink) Old 06-16-2015, 06:51 AM
TZ_280SEL's Avatar
Quoted: 39 Post(s)
So you just changed plugs. Were any of them different than the others? Blown head gasket will reveal itself in a very clean plug on that cylinder (steam cleaned as it were).
post #9 of 27 (permalink) Old 06-16-2015, 07:03 AM Thread Starter
Quoted: 5 Post(s)
yes, I have changed all spark plugs and cables. They were all so dirty but looked the same. I did a compression test on engine and it looked good. Does compression test tell if gasket is bad? here is the link to my old plugs and compression test on page 2.
http://www.benzworld.org/forums/vint...-1972-a-2.html
fzbenz is offline
post #10 of 27 (permalink) Old 06-16-2015, 07:05 AM
flyboyike's Avatar
Quoted: 70 Post(s)
Two questions:
1. How does your oil look?
2. Ditto for the coolant.
