W113 W108 Fuel Injectors - Mercedes-Benz Forum
post #1 of 26 (permalink) Old 06-09-2015, 02:59 AM Thread Starter
Date registered: Aug 2009
Vehicle: W107 W113
Quoted: 43 Post(s)
Hello,
I removed my fuel injectors from my W113 280SL and they all have terrible spray pattern, so I will have to change all of them.
Does anyone know where I can find them at a reasonable price or does anyone have tested working used ones?
Are they the same on the 230/250 models?
Thank you
R107
S320L1999 is offline
post #2 of 26 (permalink) Old 06-09-2015, 03:57 AM
Grubeguy's Avatar
Date registered: Jan 2006
Quoted: 103 Post(s)
Before you replace them have you considered soaking them in carb cleaner and blowing them out?
Grubeguy is offline
post #3 of 26 (permalink) Old 06-09-2015, 04:42 AM
kdjones99's Avatar
Date registered: Jul 2010
Vehicle: 1967 250SE (W108)
Quoted: 4 Post(s)
Mercedessource has a kit for cleaning them if you decide to go that route: https://mercedessource.com/store/bos...d-cleaning-kit
He has some videos showing the process as well.
kdjones99 is offline
post #4 of 26 (permalink) Old 06-09-2015, 06:29 AM Thread Starter
Vehicle: W107 W113
Quoted: 43 Post(s)
I had them cleaned ultrasonically and then re-tested on the pressure tester - terrible spray pattern.
R107
post #5 of 26 (permalink) Old 06-09-2015, 06:32 AM Thread Starter
Vehicle: W107 W113
Quoted: 43 Post(s)
Yes, I am aware of this kit, but as Kent says, there is no guarantee - I had them cleaned at a Bosch service and they were nice enough to invite me inside.
The ultra sonic got rid of all the deposits, they look like new on the outside (they were extremely dirty), so I infer that it did the same for the inside. However, the spray pattern did no change...
R107
post #6 of 26 (permalink) Old 06-09-2015, 06:44 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1611 Post(s)
The pintles are more than likely worn, so no amount of cleaning can fix that. I don't believe the nozzles can be replaced like diesel injectors. They should be swapped out as a complete set.
Zeitgeist is offline
post #7 of 26 (permalink) Old 06-09-2015, 07:59 AM Thread Starter
Vehicle: W107 W113
Quoted: 43 Post(s)
Yes...unfortunately...and they are expensive to replace
Any sources?
R107
post #8 of 26 (permalink) Old 06-09-2015, 03:48 PM
Grubeguy's Avatar
Quoted: 103 Post(s)
I boughtmine at Napa (I ordered them). I also bought the fuel dampers, which they had in stock. You should also try the administrator of this forum - I've had good luch with him as well.
Grubeguy is offline
post #9 of 26 (permalink) Old 06-09-2015, 05:44 PM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 47 Post(s)
Try
Partsgeek.com
Autohausaz.com
fcpeuro.com
You are across the pond I would think they are less expensive there.
Will
Baybear is offline
post #10 of 26 (permalink) Old 06-09-2015, 11:01 PM Thread Starter
Vehicle: W107 W113
Quoted: 43 Post(s)
Great - what price did you get of them?
Really do not understand why they are so expensive, very simple part compared to others...must be low volumes.
R107
