W113 W108 Fuel Injectors - Page 2 - Mercedes-Benz Forum
post #11 of 26 (permalink) Old 06-10-2015, 02:55 AM Thread Starter
Date registered: Aug 2009
Vehicle: W107 W113
Quoted: 29 Post(s)
Does anyone know if the the 230/250/280 injectors are all the same?
Thanks
R107
S320L1999 is offline
post #12 of 26 (permalink) Old 06-10-2015, 06:51 AM
Date registered: Aug 2006
Vehicle: 1998 SL500, 2010 GLK 350, 1972 300SEL 4.5, 1971 280SL, 1970 300SEL 6.3
Quoted: 37 Post(s)
The sites I listed varied from $ 101-114 USD each
Will
Baybear is offline
post #13 of 26 (permalink) Old 06-10-2015, 07:01 AM Thread Starter
Vehicle: W107 W113
Quoted: 29 Post(s)
Will
Yes, that is what I have seen. Thank you
R107
post #14 of 26 (permalink) Old 06-10-2015, 07:15 AM
Scoot's Avatar
Date registered: Oct 2002
Quoted: 118 Post(s)
Originally Posted by Zeitgeist View Post
They should be swapped out as a complete set.
Why replace all of them as a set? The reason I ask is that I'm about to go through the cleaning process with injectors for an M189, which retail for $3200 each...
Scoot is offline
post #15 of 26 (permalink) Old 06-10-2015, 07:50 AM Thread Starter
Vehicle: W107 W113
Quoted: 29 Post(s)
Wow, that is just immoral and criminal - they are very simple pieces of machined brass/bronze, no reason for these prices.
I tested each one, and they all failed unfortunately.
R107
post #16 of 26 (permalink) Old 06-10-2015, 08:04 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1541 Post(s)
You don't have to, but I like to sync up the cylinder variables on my engines so that they run smoother and more efficiently as a matched set. Kinda the same reason you typically replace spark plugs as a set
Zeitgeist is offline
post #17 of 26 (permalink) Old 06-10-2015, 08:25 AM
Scoot's Avatar
Quoted: 118 Post(s)
The M100 and M189 injectors are different -- long curved tube where the spray comes out. I doubt they are more complicated but they are unique. (M100 and M189 injectors I don't think are the same as each other, but they look similar) See attached.
Scoot is offline
post #18 of 26 (permalink) Old 06-10-2015, 08:36 AM
Quoted: 37 Post(s)
And the good thing is the M-100 injectors are much more reasonable at a list of $2500 each!
Will
Baybear is offline
post #19 of 26 (permalink) Old 06-10-2015, 09:50 AM
Scoot's Avatar
Quoted: 118 Post(s)
But you need 8 of them instead of 6, so it's just about a push.
Scoot is offline
post #20 of 26 (permalink) Old 06-10-2015, 12:36 PM
Cruise Control
Zeitgeist's Avatar
Sheesh, I think I'd convert to Megasquirt if I found out new injectors were needed
