Rear door glass replacement - Page 2 - Mercedes-Benz Forum
post #11 of 11 (permalink) Old 06-10-2015, 09:27 AM Thread Starter
Date registered: May 2015
Vehicle: 1972 300SEL 4.5
Rumb, You may be correct, I couldn't get the center post moved enough, but I think that is because I didn't pull the window channel out far enough, you also have to remove two bolts on the door to move the channel enough, if I had to do it again, I would try that.
Also found out that the seal is NOLA, tried the classic center etc... I have found a few places that carry a seal that is aftermarket, I will probably have to go that route, and they are $$. In my case the seal, even if I could have gotten it out, not sure it would have gone back in, the parts that I didn't cut out, tore off the window anyway. So be warned if you have to replace a rear door window.
The S is offline
