Sight unseen w108 purchase - Page 14 - Mercedes-Benz Forum
post #131 of 140 (permalink) Old 09-30-2016, 03:50 PM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 517 Post(s)
here are complete instructions for heater removal
rumb is offline
post #132 of 140 (permalink) Old 09-30-2016, 05:52 PM Thread Starter
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1836 Post(s)
Wow. Thanks Rumb! Maybe I should buy a nicer car to go with all this work. LOL. I'm just happy the AC fan is working.
My signature:
Click for list of my 34 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #133 of 140 (permalink) Old 10-01-2016, 01:31 PM
TZ_280SEL's Avatar
Date registered: Feb 2010
Vehicle: 1972 280SEL daily driver. 904 Dark Blue with cognac interior. euro 4.5 engine
Quoted: 39 Post(s)
Fonzi...I just did mine this spring when I did my megasquirt conversion. Yes, it is a royal PITA. You really do have toremove the radio, glovebox,center console, heater control knobs, instrument cluster, dash pad, A/C evaporator, and the heater box. I replaced mine with one purchased on E-Bay from Belarus if I remember correctly. It was cheaper (about $160 +/-) but it is the real deal and works great.
While you are doing this monumental task, I recommend doing the following; clean the heater core and replace the heater valve seals (got a LOT of mud out of mine), rebuild/replace heater knobs, buy a new A/C dryer since you will have the system depresurized, flush the AC evaporator and clean the coils, re-seal the AC box and duct work as well as the heater box and duct work. If it needs it, re-do the wood since it will all be out.
Whenyou remove the heater valves, mark them very well as there are about 16 combinations you can put them back in and only one is correct.
Good luck....it is a fun 2 days of work.
TZ_280SEL is offline
post #134 of 140 (permalink) Old 11-11-2016, 02:07 PM Thread Starter
Fonzi's Avatar
This car has been smoking crazy for a while, and it's always seemed like oil, but the compression numbers aren't that bad. And when I first start it up cold, it usually seems fine. As I was having trouble moving the car in reverse, I realized I'm out of trans fluid again, and I didn't recall seeing any massive loss on the ground. Hmm... maybe trans fluid is getting sucked up from the vacuum modulator?
So today I pulled the car away from the wood pile to remove the banjo fitting pipe from the trans to see if that would stop the smoking. Still smoking, but it's really only once it is warm. And the ecu knob seemed to have zero effect. Hmm... I bought that spare wiring harness. Maybe it's time to try it.
That was all after I set the timing. I think it was at 30btdc at idle. WAY ADVANCED! Maybe it's been Fuel in the exhaust all along. I recently got my 1985 500se with no cats to pass emissions by running it at 5btdc at idle. That seems to be the balance for minimum CO and HC. Although, I believe the spec for a 1973 4.5 is 5 btdc with no vacuum (AC on) and 5 atdc with vacuum. It seems I'm getting no vacuum pull at my distributor though.
I had to pull the distributor out to even be able to get it to 5btdc at idle.
I kind of really dug into this today with grand hopes.
So... if it doesn't run well in the really cold when the car is really cold, and it smokes when hot, maybe I've got some d-jet issues. Maybe I will try swapping wiring harnesses.
While I was in there, I decided to check the timing chain for stretch in case my timing was way off. But that didn't make too much sense, as I would get some exhaust pops when I set the timing really late. So that tells me the valves are not running late like you'd get on the passenger side when the chain is stretched. Anyway, I checked by pulling the passenger valve cover.
Timing chain looks good with only 3 degrees of stretch, original metal backed guides, and a master link on the chain at the passenger cam when near cylinder 1 TDC. Cool. Put valve cover back on and hope to stop that oil leak onto the passenger exhaust manifold.
Oh... cams look Worse than any running car I've ever had the valve cover off.
That may be an argument for getting the heads fully done or just replacing the heads.
I did not check the driver side or check the valve clearance.
So I got the rebuilt wiring harness installed and while doing it, I discovered that the throttle position sensor is way off and only gave me about 16-17 clicks. I adjusted it and now I get 20 clicks. It seems that either that (tps adjustment) or the wiring harness made the ecu knob made a big difference.
So... anyway... once the car warmed up after making all the changes, I realized that the ambient air temp sensor wires came disconnected. And when I connected those wires, the idle dropped way down. And the smoke kicked way up, and I couldn't get it to stop. It's hard for me to tell if it's oil or gas, but with the vacuum modulator pipe disconnected, I can be confident that I'm not sucking up trans fluid. Whether I've got oil or gas in the exhaust is TBD though. With the d-jet wonkiness, I'm suspecting maybe it's fuel.
I have not gotten a fuel pressure gauge ready to use, but I'm concerned that maybe I'm running rich due to high fuel pressure. Hopefully later I will get my K-jet gauges and determine what my fuel pressure is and maybe adjust it if necessary.
Edit:
Oh. I vacuumed out the engine bay and vacuumed off the remainder of the hood pad that was just making a huge mess. The engine bay of this thing is a real greasy mess. And the oil cooler seems to be leaking. So I guess I will take that from one of the parts cars.
Oh. You can see the spots where the chain has hit the head and valve cover in the past.
My signature:
Fonzi is offline
post #135 of 140 (permalink) Old 11-12-2016, 08:28 AM
Date registered: Sep 2012
Vehicle: 1988 300ce 1973 280sel 1995 E420 1998 E320
Quoted: 47 Post(s)
what color is the smoke?
knapster is offline
post #136 of 140 (permalink) Old 11-12-2016, 10:51 AM Thread Starter
Fonzi's Avatar
Looks like blue-ish white oil smoke.
I'm tracking it down in the 107 forum with the help of guys over there now. I got my spare parts and fuel pressure tester from the warehouse and will report more over in the 107 forum tomorrow.
My signature:
Fonzi is offline
post #137 of 140 (permalink) Old 11-14-2016, 02:37 PM Thread Starter
Fonzi's Avatar
Here's where I am right now. This car must have been pretty seriously messed with, or many things have gotten out of whack over time, maybe a mechanic that knew nothing about these cars??
I'm documenting the engine smoke stuff over in the 107 forum. Here's today's progress.
http://www.benzworld.org/forums/r-c1...l#post15179321
My signature:
Fonzi is offline
post #138 of 140 (permalink) Old 02-21-2017, 05:23 AM Thread Starter
Fonzi's Avatar
Last night I decided to temporarily hook up a different manifold pressure sensor that I had tested for vacuum and resistance before (and tested good). I took it out for some romping and while I've had the car run really well romping on it before, this time seemed better than ever before. The jury is still out, but I just may try and take it through the inspection lane.
It still desperately needs a valve adjustment.
I need to go hunting in the thread linked above regarding the smoke.
My signature:
Fonzi is offline
post #139 of 140 (permalink) Old 02-23-2017, 10:19 AM Thread Starter
Fonzi's Avatar
So I did a daylight test and I still get smoke on startup, but after going around the block it seems to be gone. Valve stem seals on a car that has sat makes a lot of sense. Some day! But since it seems ok after warm up, I may give inspection another run. But...
The horn. One wire from each horn was disconnected and taped off. Hmm... let's get ready to blow some fuses. I pop an old aluminum one in place of the copper blue one in slot 2. Nothing. Interesting. No blown fuses. Switch back to blue copper. Nothing. Hmm... another day I will put a meter on it. I did get the bottom horn to blow by moving wires around and pressing and pulling on the bottom horn. It seems both wires should have 12v until the horn pad grounds one and the horn blows. Right?
So I had my meter on the two wires trying to determine if the issue is my steering wheel or elsewhere while monitoring the meter through the windshield. That's when I discovered this:
It seems that depending on the rotation of the steering wheel my readings are changing significantly. Next step is to pull the steering wheel off.
My signature:
Fonzi is offline
post #140 of 140 (permalink) Old 05-09-2017, 05:29 AM Thread Starter
Fonzi's Avatar
With the steering wheel horn issue figured out, I was down to just one item that might have not allowed me to pass inspection, the exhaust smoke/fumes. It had been several weekend or even months that I'd been trying to find the time to take the car through the inspection lane. I know this engine desperately needs a valve adjustment with scoring on the cams and the exhaust cams washed clean of any residue (no gap at all). But I'm pretty confident this c at needs valve stem seals. I had done an oil change almost a year ago and discovered the oil was totally separated into sludge and then much thinner stuff on top. I think the smoking may have actually gotten worse with the oil change. Figuring I had little to lose, I added some "motor honey" to the Rotella (15w40 I believe). It took some time since I barely ever drive the car, but the smoke really seems to have subsided. Oh... I also swapped the wiring harness and the MPS. I haven't done the real "diagnostics" needed, but I think I may have actually seen an improvement with the "new" MPS.
So yesterday I was dreaming of getting time to go to DMV with the car, and it was getting more urgent because I think I may have the AMG steering wheel that I've been using for the horn sold. I might have other steering wheels that would work, but I just know this one works. So I wanted to get this inspection thing done.
Fortunately my friend with nothing to do for a few hours showed up, and after my wife fed him some lunch, he asked it I needed anything done. DMV success!
In the morning, I was noticing a little black smoke when I smashed it, which I think is an improvement from the blue / white smoke. The MPS and idle mixture may need some adjustments, but after I get this thing tagged and legal and cruising, I may take it back through for better tuning. Valve adjustment high on the list.
So excited to have this thing all legal!!
My signature:
Fonzi is offline
