Sight unseen w108 purchase - Page 10 - Mercedes-Benz Forum
post #91 of 138 (permalink) Old 06-15-2015, 10:35 AM
Kaelor's Avatar
Date registered: Apr 2015
Vehicle: 1970 W115 200/8
Quoted: 24 Post(s)
You should use some coca-cola (coke) and aluminium foil to remove those rust spots. The chrome polish won't remove them by itself, believe I've tried. either some coke or some vinegar, but you have to rinse it well after. You could also use some of those rust remover products. just make sure you don't sand those parts or don't scratch them too bad or it will stay like that forever!! Ok I might be exagerating but try not to scratch it cuz then it's a pain to buff it.
Kaelor is offline
post #92 of 138 (permalink) Old 06-22-2015, 03:12 PM Thread Starter
w108,107 Parts Hoarder
Fonzi's Avatar
Date registered: Jun 2010
Quoted: 1676 Post(s)
I know I'm on the slow boat on this project car, but I finally bought some sunroof lube, and decided to test the more economical BMW sunroof lube on this economy w108.
20g (~3/4 oz) of BMW lube: $8.74
1/2 ounce MB Lube: ~$16 delivered
1 ounce MB lube: ~$26 delivered
I will report how it goes.
Edit: next small step is to get it into the driveway and get the 205/75/14 whitewalls on 5.5 steel wheels on it and start cleaning up the paint, rust, and start my way I to diagnosing the smoking.
My signature:
Click for list of my 32 MB since 2010. If, you want 70's-80's Mercedes tuner wheels, let me know.
Fonzi is offline
post #93 of 138 (permalink) Old 06-23-2015, 02:18 AM Thread Starter
Fonzi's Avatar
I couldn't resist spending some sleeping hours on the w108.
- removed sunroof tracks, cleaned them, and tested sunroof while holding front edge up in the air. I must have a problem with the motor cable. The behavior is the same after cleaning lots of gunk off the tracks, and holding the front edge so it doesn't even contact the tracks. Well, I can open and close the sunroof, but it takes a long time. It takes lots of back and forth still.
- bolted in the seats.
- realized the car didn't come with lap belts. Hopefully the lap belts are the same as the ones in the two piece belts from a 1972-1973 450sl. I know I have at least one pair of those up in the garage attic somewhere. Thank you PetesMGA and the 1972 parts car!
- on the initial startup after sitting for maybe 9 days, it ran a little rough. I don't know how old the gas was. It could be very very old since the previous owner drove it less than 100 miles in 3-5 years. Anyway, it warmed up ok. Still it smoked, but it was late at night and I'm pretty sure everyone has their windows closed around here tonight.
- swapped the aluminum wheels for steelies with good hankook 205/75/15 whitewalls. In doing so, I realized I have four aluminum wheels, not five. One wheel is a w108 (assume 6.5") steel wheel. Since it has a 205/75/14 on it like the hankooks, it will be the spare. 5.5" with hankooks on all four corners though. I dig the look.
So it was time for a spin. I thought a little driving would be good for the car.
Oil level was good.
Transmission fluid was possibly non-existent. (Am I burning trans fluid via a bad vacuum modulator?) but my driveway isn't level, and the car drove, so I figured I would leave the ATF as is for the first drive.
On the drive, with some full throttle runs, once I saw some sparks come from the exhaust. Wow! Well, I guess it's good to blow that stuff out!
After a few miles of spirited driving and some sputtering at the starts, it was some to go to the gas station and check fluids, etc.
http://youtu.be/qkKkNWHLZR0
There was still nothing in the ATF fluid. I carefully kept adding from my 5 gallon jug, and figure I must have added at least 1.5 qts of ATF,
I filled the tank with nearly a full tank.
As I left the has station, the acceleration was immediately much better. The gas was probably old, but the smoking hadn't seemed to go away at all. It's still there, but with lots of idling, the smoke seems to nearly disappear. It's just throttling that causes big smoke plumes.
I look down and see I'm doing 90 mph on the speedometer, and the car is cruising like its 60 mph. "Ooooohh. I'm liking the w108!"
I again noticed a few sparks out the exhaust. Whoa! More sparks! Oh my! More? Since i was going so fast and distracted by sparks, I detoured my initial plan of going straight to another gas station because I was getting worried that I had actual fire coming out the tailpipe, hmm... I think, "Is this type of thing covered by insurance?" So I got off the main roads and headed up some back roads in case the car went up in flames, saving me some potential embarrassment.
Well, no worries. The car is ok, and so am I. But as I was accelerating to get back on the main roads and back to the next gas station, two deer were standing in the middle of the road, I got the chance to test out locking up the brakes. All good! :-)
It was a great little cruise and I think I may have started to fall in love with the w108. It's a comfortable big car and it's pretty easy to drive. Sure, the steering is a little twitchy, and the suspension made a little more noise than I'd like, but overall, this feels like a VERY comfortable car that is capable of today's highway speeds.
Maybe not this one, but I feel myself possibly being a long term w108 owner, preferably one of the more powerful ones.
My signature:
Fonzi is offline
post #94 of 138 (permalink) Old 06-23-2015, 06:35 AM
rumb's Avatar
Date registered: Oct 2012
Quoted: 460 Post(s)
great midnight ride!
Sounds very likely your vacuum modulator is sucking ATF. should be your next repair. that and removing the sunroof cable and greasing it. I need to to the same thing to mine.
rumb is online now
post #95 of 138 (permalink) Old 06-23-2015, 06:42 AM Thread Starter
Fonzi's Avatar
Thank you! Did you watch the walk around video (from 1:20 to 2:00) where it is barely smoking until I hit the gas pedal?
Yes. The oil level was high. The ATF level was low, and there are no significant leaks. My nose is not well enough trained to tell if it is ATF or oil burning.
My signature:
Fonzi is offline
post #96 of 138 (permalink) Old 06-23-2015, 07:01 AM
Date registered: Aug 2009
Quoted: 59 Post(s)
ATF and brake fluids burning create white smoke. Oil releases a blueish color.
Because of the lighting condition it's impossible to determine the color.
If the car sat as long as you believe it has, more than likely the valve stem seals are dried out. I'd put some miles on it and hope they swell.
The sparks could be anything. Particles of rust in the exhaust system, incompletely burnt fuel, small aliens escaping from the mother ship, etc.
Mike D is offline
post #97 of 138 (permalink) Old 06-23-2015, 07:18 AM Thread Starter
Fonzi's Avatar
I think of the smell as an oil burning smell, and the mechanic that I asked said he thought it was oil too, saying probably valve stem seals. Since then I have assumed oil.
Can you see the puff of smoke in the video? I would say white, but maybe I'm color blind.
My signature:
Fonzi is offline
post #98 of 138 (permalink) Old 06-23-2015, 07:35 AM
Quoted: 59 Post(s)
My initial impression of the video says, "oil" but it's impossible to tell the true color. Look at it in sunlight. You should be able to tell.
Run a tank or two of fresh fuel through it to clear out any traces of the old fuel from the system.
Mike D is offline
post #99 of 138 (permalink) Old 06-23-2015, 07:38 AM Thread Starter
Fonzi's Avatar
Thank you Mike D!
This earlier video (starting around 15 seconds in) does make the smoke look a little blue-ish...
http://youtu.be/xYJb77LykN0
Edit:
I will see if I can check prices on the trans modulator and see if I can install that myself. Aside from not kicking down into first and revving when I smash the gas pedal, I would say the trans does feel like it is working correctly.
Eventually, I will pull the valve covers and check the timing chain and guides, at which time I will plan on replacing the oiler tubes and valve stem seals.
I should probably also get started with some compression checks too.
My signature:
Fonzi is offline
post #100 of 138 (permalink) Old 06-23-2015, 08:10 AM
Quoted: 59 Post(s)
I'm pretty sure the "kick-down" function on the W108 is activated by the small switch beneath the accelerator pedal and not by vacuum. This is how it works on on every other '70's model of Benz I've worked on.The modulator's function is for smooth shifting at proper vacuum levels. Different from American iron.
Mike D is offline
