Rust on crankshaft journals - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 05-14-2015, 02:31 PM Thread Starter
Kaelor's Avatar
Date registered: Apr 2015
Vehicle: 1970 W115 200/8
Quoted: 24 Post(s)
Hi, the crankshaft of my W115 has some surface rust that has developed on the journals. I saw a video on youtube of a guy that polishes the journals of a crankshaft that has way more rust than mine and with good results. Is it doable?? Or do I have to grind the journals?
Kaelor is offline
post #2 of 7 (permalink) Old 05-14-2015, 08:11 PM
Premium Member
Date registered: Nov 2012
Quoted: 59 Post(s)
Premium Member
i would regrind it to the next size , but before you do that see what is available for bearings .
agillot is offline
post #3 of 7 (permalink) Old 05-15-2015, 08:23 AM Thread Starter
Kaelor's Avatar
Quoted: 24 Post(s)
I don't think there are many options avaliable on undersized bearings for that car since it's quite old. But I'll see what I can find. If not then I'll just polish them as good as they can be polished.
Kaelor is offline
post #4 of 7 (permalink) Old 05-15-2015, 09:59 AM
Cruise Control
Zeitgeist's Avatar
Date registered: Sep 2004
Vehicle: '87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
Quoted: 1466 Post(s)
Polish with emory cloth tape, and then see if there's any pitting on the journals
Zeitgeist is offline
post #5 of 7 (permalink) Old 05-15-2015, 10:06 AM Thread Starter
Kaelor's Avatar
Quoted: 24 Post(s)
What grade should I use??
Kaelor is offline
post #6 of 7 (permalink) Old 05-15-2015, 11:52 AM
Cruise Control
Zeitgeist's Avatar
I read somewhere that you typically start at 400 and work up to 1000. Depending on how rusty the journals are, you could start with 320, but probably nothing below 220
post #7 of 7 (permalink) Old 05-15-2015, 01:54 PM
Date registered: Jul 2004
Vehicle: 1971 280SE 3.5 Coupe
Quoted: 8 Post(s)
You might consider taking it to a crank shop to have it polished-then they can mic it and check the hardness. I had the 560 crank for my project totally blueprinted for $125-check for straightness, mic and magnaflux, micro polished and check the hardness on all the journals.
Noodles likes this.
Tony
280SE 3.5 Coupe
Stick shift
3.27 Axle
5.6 Iron block build in progress
3.5 Tony is offline
