My "New" '72 w114 250 - Page 4 - Mercedes-Benz Forum
post #31 of 68 (permalink) Old 05-14-2015, 06:08 PM
Bill A's Avatar
Date registered: Jan 2009
Quoted: 27 Post(s)
Originally Posted by Big Daddy Benz View Post
Thanks, all. I'm stoked about it.
I will attempt to spin the motor soon. For now, I'm soaking the cylinders with WD40 through the spark plug openings. I really don't want to take the radiator out to get to the crank bolt. Maybe I can get to it from underneath. Any best practices out there?
It is kinda close in there. Depending on the car I have removed the plugs and turned the engine using an alternator pulley nut, I have removed the valve cover and used a 22mm wrench on the cam gear bolt being careful not to collapse the tensioner so pull a bit and relax the chain and repeat, you will be trying to break the engine loose if it doesn't want to turn. If it's too tight you can get under it and try a short socket on the crankshaft pulley bolt or you can use a wide blade screwdriver and carefully turn the engine at the torque converter through the cast grate on the bottom. CAREFUL not to break the grate because I don't want to hear hollering. If you soak the cylinders with penetrant oil it will likely turn over without too much trouble. Isn't learning a fun thing.
Bill A is offline
post #32 of 68 (permalink) Old 05-14-2015, 07:38 PM Thread Starter
Big Daddy Benz's Avatar
Date registered: Mar 2015
Vehicle: 1985 w126 300SD, 1972 w114 250
Quoted: 37 Post(s)
Indeed, Bill. Loving every minute of it. Thank you for the turn-over tips!
BDB
1985 W126 300SD
1972 W114 250
Big Daddy Benz is offline
post #33 of 68 (permalink) Old 05-14-2015, 07:42 PM Thread Starter
Quoted: 37 Post(s)
While I'm under the hood, I'm noticing lots of vacuum lines broken and truncated. Shocker, I know. Is there a vacuum diagram for the whole car out there floating around?
BDB
1985 W126 300SD
1972 W114 250
post #34 of 68 (permalink) Old 05-14-2015, 08:01 PM
Bill A's Avatar
Quoted: 27 Post(s)
I'm sure there is, i know there's a forum here that has a lot of technical info. I stumbled onto it a couple of weeks ago. I'm going to be gone for a few days but if you don't find it we'll see. I donated most all of my library to our public library a couple of weeks ago of I'd just copy a page. The Fullerton library has one....
Bill A is offline
post #35 of 68 (permalink) Old 05-15-2015, 06:50 AM Thread Starter
Quoted: 37 Post(s)
I ordered this from Amazon to get me started.
BDB
BDB
1985 W126 300SD
1972 W114 250
post #36 of 68 (permalink) Old 05-15-2015, 09:42 AM Thread Starter
Quoted: 37 Post(s)
How do get this plug out? Do I have to remove the distributor?
BDB
BDB
1985 W126 300SD
1972 W114 250
post #37 of 68 (permalink) Old 05-15-2015, 09:44 AM
rumb's Avatar
Date registered: Oct 2012
Vehicle: 68 250S, 91 300se, 98 SL500, 450SEL 6.9, 14 CLS550 Past MB's; 300SD, 300E, 300TE, 190E, ML420
Quoted: 510 Post(s)
Not sure on your car, my 250S I can get to the crank bolt with a big socket, and a @3" extension. just enough room to use a ratchet handle to turn it.
Here is the carb manual again
Mercedes Benz Zenith Carb Manual | JaimeKop.com
WD40 is OK, trans fluid and acetone maybe a bit better, also it burns off nicely.
The cure for the common stuck bolt. | IH8MUD Forum
rumb is offline
post #38 of 68 (permalink) Old 05-15-2015, 02:24 PM
rumb's Avatar
Quoted: 510 Post(s)
i have a spark plug socket that you can put a box wrench on the end. or will a wiggle (universal)joint work?
[QUOTE=Big Daddy Benz;12048681]How do get this plug out? Do I have to remove the distributor?
Attachment 1439553
BDB
rumb is offline
post #39 of 68 (permalink) Old 05-15-2015, 05:35 PM Thread Starter
Quoted: 37 Post(s)
Duh. I didn't even think of using a box wrench. There was no way to get a wiggle joint on there. I'll give the box wrench a try. Thanks!
BDB
1985 W126 300SD
1972 W114 250
post #40 of 68 (permalink) Old 05-15-2015, 05:40 PM Thread Starter
Quoted: 37 Post(s)
From the top or from the bottom?
I have some lacquer thinner on hand. See any reason not to use that instead of acetone or is there some important property that acetone has other than it being a solvent?
BDB
1985 W126 300SD
1972 W114 250
