Window seals - Page 2 - Mercedes-Benz Forum
post #11 of 13 (permalink) Old 05-12-2015, 09:47 AM Thread Starter
Kaelor's Avatar
Date registered: Apr 2015
Vehicle: 1970 W115 200/8
Quoted: 24 Post(s)
Originally Posted by Bill A View Post
Yes on the silicon paste lightly and only to the vertical surfaces. the channels have a fuzzy surface that allows the glass to slide easily but the fuzz wears off so the silicon is just a temporary solution. The drivers door will usually be the worse ones as they are most often used and the rears usually don't need to much. I looked again at the "door seals" at Pelican parts and they are door seals.
Oh you are right, the weatherstrip then is the same thing but for the front doors right?
So I'll use some silicon on the channels, any type of silicone suggestion?
Kaelor is offline
post #12 of 13 (permalink) Old 05-12-2015, 09:56 AM
Bill A's Avatar
Date registered: Jan 2009
Quoted: 27 Post(s)
The silicone should be clear so you don't see it and a paste as you want it to stay put, I just used a small screwdriver to apply it inside the contact areas of the channel. i'm sure there are guys here with other ideas that may well work as well? Sil Glide is the product I have used but Mercedes has many uses for it so it doesn't go to waste. You might find it on Ebay as well.
Kaelor likes this.
Bill A is offline
post #13 of 13 (permalink) Old 05-12-2015, 10:12 AM Thread Starter
Kaelor's Avatar
Quoted: 24 Post(s)
Nice, thanks! The door seals will definetely get replaced, they are cracked and burnt.
Kaelor is offline
